Question about Dell Inspiron 2200 Notebook
Overheating problem My notebook overheats and shuts down. The vents are clear. The tech I took it too said that the lamp is heating up and causing this problem. He offered no solution and I am not sure what he means by the "lamp". Does anyone have any more information for me about this? Is this a part that can be replaced? Thank you, Deborah When on, my laptop power connection overheats when plugged in. (The adaptor into the laptop gets so hot that it is almost too hot to touch) Also the screen will go black after a few minutes of use, and will only come back if lid is closed for a few minutes. If I unplug it, and then use it - it operates fine. Do I need to replace the connection and/or the adaptor?
  • 3 Answers
Ther coud be dust bult up in the vents in between the fan and heat sink  that can block the cooling on it to whitch is not all that hard to clean out too just got to be carful when doing it
Posted on Sep 08, 2008
This could be several issues with this machine why it could be overheating could be a software issue on the machine could be a bad fan could be processor issue, instead of spending a bunch of money trying new things it could be a small issue. Send it to the fastlaptoprepair.com they have fixed my machine with a different issue but it was fast and very inexpensive.
Posted on Apr 19, 2008
  • Dell Master
  • 19,396 Answers
With all respect for the repairman, he must have been a bit confused.
The only lamp inside a laptop is the one behind the display, and when it overheats, the laptop does not shut down. The lamp blows and laptop keep working with no picture or dim picture on screen, that is all.
Most common cause for overheating on a laptop is the fan on top of CPU, if it is not working properly or not well adhering to cpu surface, then the laptop will turn off after a while.
When fan is ok,a faulty motherboard or faulty CPU can cause the computer to shut down, no lamp at all in all this, the repairman must have confused your laptop with a laser printer.
Here is a tool to check computer temperature and fan speed, click where it says SpeedFan 4.33. under download.
...if you cannot fix it by yourself I suggest changing repairman...
regards
Posted on Mar 19, 2008
  • Ginko
    Ginko Mar 19, 2008
    Well... solution above was for debora's problem, second post with adapter overheating is a different matter.
    If it is the adapter in overheating change it immediately. The adapter overheats when there is a short circuit inside the adapter. Do not use such a faulty adapter, it is an hazard for you and for the laptop, as it can blow at any time.
    Dell adapters are not expensive, you can buy a replacement on ebay for 15 or 20 $$. Change it immediately
    regards
SOURCE:
Computer shuts down after 10-15 min
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
May 13, 2013 | ASUS Eee 900 Notebook
How to resolve the overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
Apr 07, 2013 | HP G60-127NR Notebook
Compaq Presario 1700T overheats and shuts down
Mar 26, 2013 | HP Compaq Presario 1700T Notebook
Compaq Presario F767NR wifi overheating video card
Jan 29, 2013 | Compaq Presario F767NR Notebook
Overheating amilo
Jan 26, 2013 | Fujitsu AMILO Li 2727 Notebook
Suddenly shut down
Oct 30, 2012 | Dell Vostro 3750 PC Notebook
My acer notebook 1 keep shut down
Aug 25, 2012 | Acer Aspire One PC Notebook
Acer guet hot end shut down
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 02, 2012 | Acer Aspire 5315 Notebook
Overheating on Compaq Presario Notebook Model C501NR
May 18, 2012 | Microsoft Compaq Presario C501nr Notebook
Auto shut down
The CPU could be overheating.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 26, 2012 | Lenovo G530 154Inch Laptop (Black Matte)...
Dell Inspiron 2200 Notebook Logo
226 people viewed this question
Ekse
Clive
Clive
