Singer 1525 Mechanical Sewing Machine Logo
Posted on Apr 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fill the bobbin on a singer sewing machine model #1525
Anonymous
Level 2:
  • Expert 139 Answers
  • Posted on Apr 16, 2010
Anonymous
Expert
Level 2:
Answers
139
Questions
0
Helped
69328
Points
217
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
1helpful
My bobbin in my Singer sewing machine 4522 case will not click back in. It is a Singer model 4522. It had been stored and unused for a while. I oiled it up and bought new Singer clear plastic bobbins.
Did you get Class 66 bobbins? See https://www.sewingpartsonline.com/singer-4522-sewing-machine-parts.aspx?index=19 . Singer sewing machines use a variety of different bobbins.
I hope this helps.
(I have an older Singer Touch N' Sew. Those bobbins are easy to spot. Newer machines can use Class 15, Class 15J or Class 66 bobbins, https://www.singer.com/sewing-resources/complete-bobbin-guide . Some machines can only use either the plastic or metal bobbins of a particular size. Others can use either metal or plastic bobbins.)
How to thread a singer sewing machine serial ZHC313405023 Model 1525?
It's possible that you do not have your bobbin or bobbin case in correctly. If you do not have your user's manual (which you should use like your bible), download it free at the Singer website. Review the threading steps for both top and bottom.
One more VERY IMPORTANT thing. On ANY model sewing machine going back to their invention from any company, you MUST thread with the presser foot UP. That is because there are tension disks that apply tension to the upper thread that are ONLY spread apart when the foot is up. If it's down, the thread can't get between them, and there's no tension on the upper thread. That might also be your problem.
1helpful
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Filling bobbin
is it still under warrenty where you can take it back?
Apr 09, 2012 • Singer 1507
2helpful
How to fill bobbin on singer 9124 sewing machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9124 ) & click search
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
I lost my instruction manual
You can find free manuals to down load from singer ..
http://www.singerco.com/accessories/manuals.html
Please vote !!
23helpful
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
9helpful
3answers
Singer Futura 900
Here is a FREE manual for the Singer Futura 900
http://www.singerco.com/uploads/download/a519b77b90074797a4f001327810f68ccb64f3d1.pdf
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
