Question about HP Compaq Presario V6000T Notebook
Screen stays black
On startup the screen flickers and then stays black
  • gusstavoblas Oct 28, 2008
    my HP altec lansing i try to log in and then the screen goes black and all the buttons stay black but on a different user is fine expt the internet i cannot connect.
    Genius:
  • 1,601 Answers
Your inverter board is bad. It is time to change it.
This manual page 152 will show you what is involved.
http://h10032.www1.hp.com/ctg/Manual/c01035886.pdf
Posted on Mar 23, 2008
When i switch my compaq presario v6000 the screen stays black and the volume and power button switchs on and off, but nothing shows up on screen....does any1 noe the problem
repli asap
thank uu
Posted on Oct 27, 2008
4 Suggested Answers
SOURCE:
rockitman187
  • 2559 Answers
SOURCE: Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Posted on Jan 07, 2009
Geekman
  • 32281 Answers
SOURCE: laptop screen flickering
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Aug 05, 2009
  • 38 Answers
SOURCE: Dell Latitude CPt screen is black at startup and stays.
It sounds like your PC isn't completing its POST. (pre operating system test)
This is usually caused by faulty hardware. Your best bet is to first remove anything you have recently installed. If that doesn't apply/work, try removing various hardware devices (CD/DVD drives, memory, USB devices) until you get the machine to boot up.
If even after removing every piece of hardware possible the machine still exhibits the same behavior, it is likely a problem with the motherboard (or other "permanent" hardware).
Posted on Mar 18, 2009
Boots fine but screen but monitor flickers then goes black. Is it the monitor or something else?
What operating system are you usign?
Presuming it's Windows, wWhen you say "boots fine" you mean you actually reach the desktop, the "welcome" screen or the Windows startup logo?
By your description somehow I guess you have a startup problem but need some feedback about your computers status
Jul 09, 2015 | Computers & Internet
My aspire 5830t screen flicker at startup
I suspect the backlight or inverter may be faulty. Check on flea bay for replacement prices.
Dec 21, 2013 | Computers & Internet
Black screen after startup
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 05, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Hp nx9010 notebook red screen on startup and red bleed on picture
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 10, 2009 | HP Compaq nx9010
Screen stays black
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Startup
Black Screen shows memory counting which stops at 256 Mb [is correct] Hit F10 & screen says "Setup" in bottom right hand corner-screen is still black. Floppy Drive Bay green light staying on. Regards John
Jul 10, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
HP Compaq Presario V6000T Notebook Logo
658 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
