Question about Toshiba Satellite 2410-S203 Notebook
Toshiba satellite 2410 black strip (1cm) on the right hand side from top to bottom
Hi, when I fire up the computer, the full screen is being used by the usual prewindows installation screen, however when it gets inside windows, with the desktop and all, the black strip appears. anything I can do?
    Problem Solver:
  • 17 Answers
Install the VGA card from the TOSHIBA driver disc and then reboot
Posted on Jun 01, 2008
How do you open up a Sony rm-gd008 remote for cleaning?
  1. Maybe worth a shot, carefully thou
  2. Remove 2 * screws under battery cover
  3. front of remote: slide down the bottom cover (where rec, pause, etc option is)
  4. push both egdes of the slide area outwards, to totally remove this slide cover
  5. further more, now push both the above slide edges even more .. till bottom of (front face) cover loosens up. Whilst lifting this only a little at a time ...
  6. Gently remove /loosens only lower ends (only at this stage) of the 2 silver edge stripes... by .. lifting up (away from face of remote) ..whilst .. moving them outwards. ** i.e up, then outwards) Do not remove top edge of silver tip yet
  7. start separating left n right egdes with sharp flat point from under silver side strip, " digging" downwards towards bottom of remote
  8. At this point, the top edge of remote may be separated, but not necessary.. if you can pull insides out from bottom, PREFFERED OR .. can be done by:
  9. using flat edge - loosen/pry 1cm from corner on top tip of edge left n right digging downwards n outwards towards bottom of remote .. enough gap to use a little pressure if you must
  10. then if feasible, separate remote face .. also 1cm from right n left corner alongst each side from top corner
  11. .. now can remove silver side strip completey.
  12. Hope this helps, cheers
Dec 04, 2012 | Televison & Video
How can i enable/disable the internal wifi card on my toshiba l455d-s5976 notebook
Click on the wifi icon on bottom right hand side of screen,,go to network and sharing,,,right click your connection on the screen ,,go under properties,,disable ,,and enable options,,,also should have a wifi on off switch ,,be the best thing and easiest,,,should be on right hand side of laptop towords the front,,a switch ,,if not check on the top of keyboard,,either sAy wifi or have icon,,,good luck,,also,,toshiba website ,,support ,,can help ,,
Dec 21, 2011 | Toshiba Satellite L455D-S5976 Notebook
CANNOT FIND WHERE U PUT BLACK AND WHITE WIRE THAT GO AROUND SCREEN ,TOSHIBA L455D
One wire runs up the left hand side and the other runs up the right hand side of ther screen and stick to the pieces od double sided copper in towards the top centre ot the screen. The position is not critical at all. As long as they are somewhere near, it is fine.
Jan 29, 2011 | Toshiba Satellite L455DS5976 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Toshiba Satellite 2410-S203 query on ram upgrade
Yes u can, i just upgrade my toshiba 2410 ram to 1gig ddr1 a few weeks ago
Jan 31, 2009 | Toshiba Satellite 2410-S203 Notebook
Toshiba Satellite A85 Optical Drive swap
36ec1a1.jpgHi, this is not the best picture but its this751c93d.jpge only one I can find so far. and yes screws can be hidden underneath stickers I have seen that before.
e3bbac5.jpgsave these to your computer and use a photo program to enlarge them so you can see them.
I hope this helps.
Oct 26, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite 2410 note book
i don't get the meaning of your description, but you can try to adjust the resolution of the screen by click the space of the desktop, choose "attribute", then choose "setting",change the "screnn resolution" to 1024x768 pixel.if it does not work, reinstall the windows opration system.
Toshib stellite 2410 battery
Apr 24, 2008 | Toshiba Satellite 2410-S203 Notebook
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
MacBook opening screen leaves a one inch black strip on both sides.
use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Mar 21, 2008 | Apple MacBook PC Notebook
Toshiba Satellite 2410-S203 Notebook Logo
210 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
