Question about HP DeskJet 970cxi InkJet Printer
Problem with color cartridge
I've not used my DeskJet 970 in a while. Recently reconnected it and turned it on. There was a flashing light indicating a problem with a cartridge. On opening the lid the arrow points to the sad face for the color cartridge.
I've tried reseating the cartridge (taking it out and putting it back in again), tried refilling the cartridge (altho that would have shown up as a low-ink rather than sad face symbol). On another site someone suggested it may be because the lid isn't closing properly but I've tested and ruled that out.
Any other suggestions?
  • Anonymous Mar 24, 2008
    I changed the color cartridge, then the center light started flashing. I put the original cartridge back in and unit still flashes. I tried a new cartridge, some thing. I cleaned all contacts on printer cartridge and carriage, but still flashing. What next? Daryl
  • Anonymous Apr 02, 2008
    same problem red blinking light does not go out. Both cartridges are new
    Problem Solver:
  • 4 Answers
Your ink cartridge opening may have dried up. Try replacing the catridge with a new one. Should resolve te problem.
Posted on Mar 19, 2008
SOURCE:
Printer says cartridge is out of ink but is practically new and hardly been used
Is it the original Hp catridge or you refilled it..???? you've replaced the black... so no problem with black.... color catridge would have dried... so remove th color catridge and wipe thi lower part gently with a wet cloth....!!!
Mar 23, 2012 | HP DeskJet 6988 Printer
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
My printer model is HP Deskjet F4288 All in one printer. Recently i ve brought new Color catridge and re filled Black and white catridge today but still it is showing not able to take print out.
OK, HP recommends that new HP cartridges be used rather than refilling. I've had better results with new cartridges that are name brand than trying to refill to save money.
Feb 04, 2011 | HP DeskJet F4280 All In One Printer InkJet
WHAT DOES THE TOP TEAR DROP SHAPED BUTTON MEAN WHEN IT IS FLASHING ON A HP DESKJET 3820
The flashing teardrop light indicates your ink is about out.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | HP DeskJet 3820 InkJet Printer
I can't get my HP DeskJet F300 series back online.I ve done everything, I ve even stopped the print spooler and started it again but the same problem still exists.And another problem that the ink cartidge...
First, the cartridges. This printer uses a 21 for Black and a 22 Tri-Color. The 58 is a Photo cartridge that replaces the 22, not the 21. Make sure that the cartridges are properly placed in the printer. The next step is the easier one. Might sound like some work, but it is the best way to correct conflicts with HP branded printers. First, uninstall the printer from the PC completely. Use the uninstall function. When that is done, re-install the printer onto the PC and test it. This should solve your problems, as long as there is not physical issues with the printer itself.
Sep 26, 2009 | HP DeskJet F380 All-In-One Printer
Flashing orange light
My printer will only print when both cartridges are installed, regardless of what I am printing.
May 13, 2009 | HP DeskJet 970cxi InkJet Printer
Out of paper light flashes even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
No paper light ligted even after paper is loaded
4. paper jammed
Urgent printing!
Replace color cartridge so the printer doesn't consider it an error. You can print grayscale only in your print settings.
Nov 02, 2008 | HP DeskJet 970cse InkJet Printer
Error message
cartridge short. chek bleck cartridge
Jan 12, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
165 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
