AWM1404/4 whirlpool skips wash programmes
Hi
I have a whirlpool AWM1404/4 washing machine that has started skipping wash programmes. The dial is very stiff and when I put it on wash programmes 8 or 9 it fiulls with water agitates for a couple of mins then drains and goes straight into rinse cycles. Help!!
  • GillG Mar 20, 2008
    I shall get the hubby to try that for me over this long weekend. Thanks for your help.
  • Anonymous Mar 15, 2014
    we had put it on a programme but isn't moving it seems its on delay
    Sergeant:
  • 351 Answers
Try some wd40 spray around timer shaft.but yot may have to replace the timer hope this helps.
Posted on Mar 19, 2008
SOURCE:
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
How to reset whirlpool 6th sense washing machine
We have just bought a whirlpool zen 6th sence when we tried to do 1st wash without clothing we couldn't get the programme dial to move or wash to start. It just has 6.00 and a washer and 8 on its side symbol
Aug 20, 2013 | Whirlpool Washing Machines
Why does the aquapump light come on when there appears to be no fault on my easytronic 1000 washing machine
hi this fault could be the programmer try selecting spin cycle see if it skips programs
regards
shaun
Oct 29, 2011 | Washing Machines
After selecting the wash programme sounds as if machine about to fill with water but at this point it defaults to start/pause. Have tried selecting reset/skip button but repeats the same problem, please...
Is there any water filling into the machine? If not then the filters on the machine may be clogged up and need to be cleaned? There is also a filter on the hose of the machine where it connects to the water mains pipe.
It just means removing them and rinsing them under the tap.
May 22, 2011 | Washing Machines
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Our older top loading Whirlpool washer skips FILL
It sounds like you have a timer going bad.
Mar 06, 2010 | Washing Machines
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
I have a Beko washer WMA 1613S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number...
I have a Beko washer WMA 1510S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number settings.
Andrea
Aug 30, 2008 | Washing Machines
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
