Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon 6502 error
Hi , I just want to know what does take the right hand side cart means .I'm trying to do the same technique with no success
  • 4,041 Answers
Hi there
You can only try.
Solution:
1. Unplug the printer.
2. Remove the faulty Cartridge
3. Plug in the printer and press and hold power button
4. Keep it held down. Press Resume twice, and this should reset the fault.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Error 6502 came up on my viewing box and I cant get it to clear. I dont know what caused it exactly. I had a paper jam and I pulled the paper out of the rollers to clear it now I have error 6502 and I dont...
Pls do the following :-
Error code 6502 The Error code 6502 can occur in the printer as a result of ink tubes caught under housing and jammed the print head against the right hand side of the printer. The printer is unable to do anything now and it will give an alarm light only. To fix this issue, you need to unplug the printer and then plug it back. You need to press and hold the power button of the printer and click the Stop button twice. You can then release the Power button and press Stop button for four times. The issue will be fixed and you can start your print jobs.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX700 Office All-In-One InkJet...
Canon mx700 has a code 6502, what I have should?
code 6502 Please do the following:
1. With the printer unplug, remove the ink cart to the right ,
2. Plug in the printer
3 Press the POWER button and do not release the POWER button
4. Press the RESUME button twice in succession.
5. Now release the POWER button
6. Ppress the RESUME button 4 times.
The printer may beep. Unplugg the printer, reinstall ink and plug it back in. This should clear the issue.
All the best Pineworks
Apr 27, 2010 | Canon MX700 Office All-In-One InkJet...
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Code error 6502
How to RESET the Error code “6502” for CANON ip4300 ? maybe following tips can help you:
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished.
Mar 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma iP6600D error code
Error Code 6502 appears generally after chaging a cartridge.
Solution:
Oct 06, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error code 6502 on my canon printer
2,Plug in the printer ,Press the POWER button, Do not release the POWERbutton ,and then press the RESUME button twice in succession .Nowrelease the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,afterthat reset the printer electronics ,open the printer and this processis finished.
Sep 17, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Error 6502
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
May 31, 2008 | Canon MX700 Office All-In-One InkJet...
Error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
May 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error 6502
Have you replaced the ink cartridge recently? Service error 6502 is an ink tank position sensor error. Service error 6502 generally means that your ink cartridge chips cannot be recognised. The primary cause of this is the blockage of the LED. Ensure that no tape, glue etc is covering the chip or LED on the rear of the cartridge. Problem more prevalent on third party replacement cartridges or ink systems.
Jul 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Error code
hi peepz,Just to share CANON MP800 Error CODE 6502:I have been using INKRIS.com CISS system for years now until this stupid problem came up.to further clarify,
1)Lift the Lid.
2)switch off the printer by pulling out the plug.
3)then shift the ink cartS to the right.
4)close lid,plug in power.
5)HOLD DOWN power button then press STOP/RESET button twice.
6)Then press STOP?reset button 4 times.
7)the screen on MP800 will go white.with SPF test mode Idel written on it.
8)then power off and power on again.
THANKS for SAVING MY PRINTER!
Dec 12, 2006 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
198 people viewed this question
old marine
old marine
