I've got an old toshiba laptop with a broken usb hub
Do i need a new motherboard and if so how much would it cost
    Scholar:
  • 135 Answers
Hi
replacing motherboards on laptops out of warranty normally works out too expensive...
And yes, you would more than likely need to replace the mainboard, since almost all components of laptops are part of the mainboard...
Posted on Mar 19, 2008
Toshiba laptop Satellite serial 17147597K
The answer to the cost vs. benefit equation is dump it, especially if is more than 5 years old.
Jan 28, 2014 | Toshiba Satellite Computers & Internet
I have a broken Toshiba laptop, [the battery died]..and I have photos stored on it..is it possible to retrieve the photos?.. I also have a new Toshiba laptop...please help??
I don't think you lose data because battery is dead. Data is on your HD. Why don't you connect it to power supply and see if the old laptop is really working.
Aug 13, 2013 | Toshiba Computers & Internet
Need motherboard for Toshiba laptop Satellite M100
You need to contact the Toshiba support center close to your place to get the replacement motherboard. Now before this is ordered estimate the total cost of the board, including freight/insurance. If higher than expected you must try to get yourr old set bartered for spares and then decide to go in for a new laptop.-- even if the cost is higher by spending an extra 30 %. to the cost of the new board.
good luck.
Sep 02, 2011 | Toshiba Computers & Internet
I have a toshiba satelite l510 laptop.i put the charger pin(plugged) on the usb port of the laptop.The middle black part of the usb port is pushed inside and then all the external devices like...
What you need is to have the USB board replaced.It's a small part that costs $29.95 at Impact computers.I'm sorry to say , but I don't think your technician is teling you the truth; I see this a lot with repair shops and technicians.
Here's a link to pictures of your motherboard, and a link to the part you need, on the Impact computer website.
Your Motherboard: http://www.impactcomputers.com/k000045520.html
Your USB board: http://www.impactcomputers.com/k000045050.html This goes on your motherboard.
The problem you will still have is to disassemble the computer,remove the damaged USB board,solder a new one in,and re-assemble your computer. the labor for the repair is gonna cost you at least $100.
Mar 03, 2011 | Toshiba Satellite A135-S4527 Notebook
My toshiba dynabook satellite 2140 says you need a disc to update your BIOS..what should i do?and my son accidentally sprinkled some water on the keyboard..is there a possibility to fix the problem or...
No, do not throw away. completely dry and try again. You can sometimes use a USB keyboard. REplacement keyboards for laptops are surpirisingly cheap, not counting install, but typically install is not serious, often no case opening...Toshiba, however, is sometimes a different story.....
A note about computers, Lower cost and seriously better stability are the reason to look at a new computer. Essentially, with an old machine, you put most of the cost of a new machine into repairs. but you still have an old machine....... Which will fail someday....
ALWAYS back up your data and All user files, like contact lists...E-mail addresses....
Oct 08, 2010 | Toshiba Computers & Internet
Do you have to replace the mother board for USB replacements
Hello, yes you are right for that USB replacement you need to replace the motherboard, as USB port is Onboard.
Cheaper solution... there are adapters available that can convert your serial port to USB. Then purchase a 4 (or more) USB hub, to plug into that.
Apr 15, 2010 | Toshiba Satellite A215-S7422 Notebook
Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Mar 18, 2009 | Toshiba Satellite A105 Notebook
USB Flash drive broken
Have to be taken to either your local PC repair shop or sent back to the manufacturer. I would send it back to the manufacturer because they are more familiar with your system. There is nothing you can do to fix it has to be fixed on motherboard.
Don't forget to rate this solution..
Jan 11, 2009 | Computers & Internet
My Toshiba Satellite PC hangs when I insert any USB device
To reinstall USB drivers, you need to reinstall the system, as USB root hub drivers are built in on Windows.
Tray first removing laptop battery and unplugging AC charger for ten or fifteen minutes, this will get rid of static charges that can cause USB not to work.
If that does not solve the problem then you need to reinstall Windows, in this case, try a system restore first.
If all that still does not work, then there is an hardware fault, in that case you often need to replace the motherboard.
Jan 02, 2009 | Toshiba Satellite A105 Notebook
Mother board crashed
Most likely replacing your motherboard will cost a ton of money (either the part, or the work and labor will cost a lot) . It would probably cost less to buy a used laptop with the same specs:
http://cgi.ebay.com/Toshiba-satellite-m115-s3094-core-duo-laptop_W0QQitemZ250273284600QQihZ015QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If your laptop is under warranty, disregard what I just said, but if it isn't I would sell your broken laptop on ebay, and buy a new or used one.
If you want to keep your old data, you can just swap out your hard drive.
Hope this helps.
Jul 27, 2008 | Intel Motherboard
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
