Machine does not start and trips the ELCB
I have disconnected the heater element, and the water pump. Boteh work without tripping. What is the most probable fault area?
Regards
Joe
    Sergeant:
  • 351 Answers
Most of the time its the element but check to see if theres any water leaks onto the motor element or pump.it could also be a worn wire touching the frame.hope this helps.
Posted on Mar 19, 2008
Tripping ELCB (RCB)
sounds to me like a short circuit in the heating coil circuit. One would have to ohm out the coils.
Jan 30, 2014 | Miele T8005 Tumble Dryer
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
My washing machine keeps tripping the electrics everytime i switch it on, i have tried different sockets and the same thing happens. I have only had the washer 2 days and it was working fine, i got this...
If its a new machine then call repairman under Warranty. If not then could be the Heater Element disconnect one side of the wiring to see if machine can run without blowing ELCB
Jan 22, 2011 | Washing Machines
Colman Spa trips GFI what is most common problem? GFI test good. Pump disconnected still trips, is heater most likely? Can you replace only heater? thanks
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
Dec 31, 2010 | Balboa Instruments BALBOA 30kW HEATER ASSY...
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
