Question about HP Compaq Motherboard
Hp motherboard startup problem!!
Hi my hp pc will not startup...its going on yes but nothing on screen...i have change the ram try another cpu and it still do the same..its an very small hp pc desktop pc
  • 6 more comments
  • Andries
    Andries Mar 19, 2008
    it has onboard vga...but i have a pci vga card and the problem still there...thik my boss brake it
  • Andries
    the smp what's that and where? the strange thing is the cpu does not get warm? i have tried another one but it still the same...its weard....
  • Andries
    the pc allmost look like this...
  • Andries
    thanx..but it seems there is no beeps..i know some of the beep codes and there is nothing only the fans are working...do you want a pic of the motherboard?
  • Andries
    Okay i have tried it...have the vacuum cleaner and **** it almost to the end..but stil no long beep and have no ram in it...have tried the same cpu..looks like the motherboard is moertoe!
    P.S and the original cpu works fine
  • Andries
    okay i will try that thanx...this is weard powersupply it has 3 plugs the one plug has an 10pin connector the other one has an 8pin connector and the last one has an 4pin connector this is an hp pc think it has an hipro power supply..but i will try the battery thing...and let you kow...thanx
  • Andries
    Andries Mar 20, 2008
    flash of the bios? how? still no beeps...nothing only the fans that is running...
  • andruil27 Dec 09, 2008
    i have the same problem with amethyst m motherboard just with one diference it starts after few restarting
  • 655 Answers
Hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. hp motherboard startup problem!! - 86c6af2.jpg
Thanks
Iqbal
Posted on Mar 19, 2008
  • Iqbal Husain
    Iqbal Husain Mar 19, 2008
    The fans are working means your SMPS is Ok and power supply goes to the mainboard.
    Now your board or CPU may have faulty. If you have vaccume cleaner clean the CPU socket on the board. It might be dusty and your CPU might not be connected properly.
    So after cleaning the socket. Attach CPU and try to hear the long beep for missing RAM. If not then make connection slightly temper to the board and try agian.
    If you have another CPU of same configuration, you should try it.
    Thanks
    Iqbal
    Genius:
  • 1,027 Answers
As a last resort I would try a flash of the BIOS.
If the bios was corrupt you would get no beeps and no video.
    Novelist:
    Champion:
  • 236 Answers
Try this my friend... remove the cmos battery for at least 5mins.
while the battery is out, set the jumper settings to clear CMOS. few seconds only then put back to save CMOS settings.
after 5mins, put back the battery, plcae your CPU, sonnect your power supply.... can you see if your board uses an support power supply 12Volts for the newer CPUs. its a four pin colored yellow black wires. this has to be connected to your board. But if this models supported only by 20pin power supply then you will not find the 4pin additional power jacks for the board. anyway, try this battery thing to reset the whole system. it may work.
redrivera0314@yahoo.com
  • Redentor Rivera Mar 26, 2008
    try changing your power supply, if still does not work then you have a defective system board, only compaq can handle repair. forget about flashing bios etc... change your power supply. remove also your PCI video card and use your on board. remove all other peripherals just the basic then try to run the board with new power supply ATX.
  • 117 Answers
Have you try to change the smps. check the power goad signal from the smps
the signal wire is in GREY colour and the signal will be 5volts
  • sathish kumar
    sathish kumar Mar 24, 2008
    hi
    i said change the smps .it is where you plug the power cord in the system
Try reconnecting your video card it may be loose or full of dirt
I have hp pavilion dv2000, when I plug in dc cord it switches on without pressing power switch. Than I'm able to switch it off and on. All lights on panel and motherboard switch on also. CPU fan switches...
dv2000 zero support now at hp,
2006? year.
so does the VGA port on the rear of PC work. to a desktop monitor
yes, then the mobo is ok. but not screen.
easy no?
i can make the mobo run on a table. vga connected.
with Fn+F4 toggled on and external USB keyboard, I can activate the external screen.
steps. are as follows. in proper order
1: remove that shorted huge battery, there. get it out of there.
2: make sure the power pack reads (VM) 19vdc at the jack.
3: new coin cell if voltage on its pins below 2.9v... yah?
4: get BIOS screens working FIRST. disconnect HDD and DVD drive. now.
5: go to 1 ram stick bank 0 (try 2nd one by self)
6: does the flashlight trick work on that CCFL screen,?
7: remove all modules from MOBO cept CPU and 1 stick RAM?
we call that the strip down tests.\
8: beep codes, or Caps lock key flash codes? what?
BIOS screens have to work, or mobo is dead.
has anyone been playing with BIOS doing crazy things like flashing it.>? yes, oops now you bricked it. then what (ask)
if pc is 2008 that is the solderball from hell year.
see that and the CCFL test here.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 16, 2017 | HP 417035-001 - HP Pavilion dv2000 Series...
4 beeps at startup and black screen
To Whom It May Concern,
I am very sorry that you are experiencing this problem. I will do anything i can do to help. You will have to reinstall your Operating System to fix this problem.
Thanks,
FixYa Expert
****Please Rate Thumbs Up if you like my Solution****
Jul 14, 2011 | HP Pavilion dv2000t 14.1" Notebook Laptop...
When startup button is pressed fan runs and orange LED comes on for a second and then stops (have changed motherboard and tested with different PSU still not working).
Hello!
Try only motherboard, ram and CPU, without keyboard, mouse, grafik card, hard disk, cd or dvd rom. If you have one normal beep, you have trouble with some of another parts.
If you still have a problem try motherboard, another ram and CPU.
If you still have a problem, than you have trouble with CPU.
Oct 30, 2009 | Dell Dimension E521 PC Desktop
My PC dosn't work
Try cleaning the RAM as shown in the image below:
If problems persist. Replace the RAM. Hope this helps.
Oct 07, 2009 | HP Compaq d330 (DG315A) PC Desktop
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
Jun 08, 2009 | Abit nForce2 NF7-S2 Motherboard
NFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | EliteGroup nForce3-A Motherboard
Motherboard startup problem!!
If your video is running off the card then remove the cable and plug it into onboard vga. Then remove the card from the slot. That should solve it then you will need to reinstall drivers for video card. If your monitor is running from onboard video then you will need to remove the card then try turning it on.
Dec 25, 2008 | Compaq Evo D310M 845G P4 Motherboard
Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
Can not get any boot at all
Hi, First of all, your hard drive is what this computer needs to boot up. Try to see if you can POST, that is, only plug in power supply to motherboard with cpu and memory in there. Don't put any hard drive or other device into motherboard as yet. see if it reaches past post. If it does, then plug in hard drive and see if the problem occurs again. If it does, then the problem is the hard drive. But for now try reaching past post with only the bare necessary components for startup. Then let me know what happens.
May 02, 2007 | ASUS P4S800-MX Motherboard
HP Compaq Motherboard Logo
814 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
