Question about HP Color LaserJet 4650DTN Printer
Insert C toner cartridge
Hey there.
I have a stubborn error on a HP CLJ 4600 series.
Keeps telling me that to replace the C print cartridge.
I've replaced it with any other cartridge in Diag mode but nothing changed, it prints without C position.
I've replaced: Mem antenna, Antenna controller, dc controller, HVPS, ETB, I even replaced the HVPS contacts to the Cartridge and to the ETB.
Any other sugestions?
  • 2 more comments
  • Sebastian Munteanu
    Sebastian Munteanu Mar 28, 2008
    I've updated the firmware, also replaced the main board.
    Same problem.
    :) yeah, of course... this printer is a real pain in the...
    Sebastian Munteanu Apr 02, 2008
    I'll dive again this week into the printer, I'll be back with info.
    Sebastian Munteanu Apr 21, 2008
    I've replaced 2 weeks ago all the parts above including the original parts from the printer to another identical printer. They were functional.
    It's a voodoo
  • 22 Answers
PRINT AN ERROR LOG. EXPECT CALIBRATION ERRORS. LASER FOR CYAN IS DEAD OR OBSTRUCTED.
Posted on Jun 24, 2008
Had the same problem with my 4600,had to change the dc controller with a known good one to fix problem
Posted on Apr 18, 2008
  • 89 Answers
Have you tried upadtaing the firmware?
Posted on Mar 24, 2008
  • Janet Baker
    Janet Baker Mar 28, 2008
    wow, sounds like you have changed everything I can think of. I am sure by now you have tried another new toner cartridge and made sure the plastic tab was fully removed before putting it in.
SOURCE:
Hp clj 2025 cleaning
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Jan 20, 2014 | HP Office Equipment & Supplies
HP CLJ 5500
If you mean toner, you can probably do it, but most new printers have a memory chip on the cartridge which keeps track of toner. Adding toner will not change the count and the printer will ignore the new toner
Jan 04, 2014 | HP LaserJet 9500mfp Printer
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
Printing blank pages
First step : Try to pull-out toner cartridge then shake it and insert again test print. if same problem appear.
Second step : change new toner cartridge.
third step : Try to contact HP service center.
http://www.hp.com
Jun 03, 2011 | HP LaserJet P2015 Printer
HP 4015x and I get an insert black cartridge error. Not sure what I should be replacing on it or what to check on the printer.
Thank you for contacting FixYa with your printer inquiry.
This error is most common when your toner cartridge has reached it's end of life. Sometimes it will alternate with "This cartridge has reached a low threshold error" which indicates you can keep printing but need to order a new toner cartridge. See page 155 of your support manual for more on this error.
See page #117 of your user guide for toner installation instructions. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
If you have installed a new toner cartridge and receive "Remove Shipping Lock Error" that means you have not removed the protective strip on page 118 step #5.
You can order new toner cartridge from HP PartSurfer or retail merchant where printer purchased.
http://partsurfer.hp.com/Search.aspx?SearchText=CB511A CC364-67902 Black print cartridge - Prints approximately 24,000 pages per cartridge CC364-67901 Black print cartridge - Prints approximately 10,000 pages per cartridge
Hope this helps helps. Please keep us updated and remember to rate this answer.
Mar 30, 2011 | HP Laserjet P4015x Printer
My printer has two cartriges that are empty would that prevent it from printing ?
Yes the HP CLJ 2600n printer will stop printing when a toner cartridge registers as empty. The cartridges will have to be replaced or You could use the "overide out" option. This allows continued printing even though the supply registers as empty. Beware that diagnosing print quality problems because of toner becomes more difficult.
Overide Out
To change this go to the PRINT QUALITY menu then REPLACE SUPPLIES and change the setting from "stop at out" to "overide out".
Jun 16, 2010 | HP Color LaserJet 2600n Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
HP 2820 CLJ, ONLY PRINTS DOWN ONE SIDE
ok typical carousel misalignment
http://www.fixya.com/support/t400576-printing_right_side_only#SameProblemContinued
just take a big screwdriver and check for stuck cartridges
Nov 05, 2008 | HP LaserJet 2820 Printer
HP CLJ 3550n
Are you using genuine hp cartridges?
Jan 07, 2008 | Office Equipment & Supplies
HP Color LaserJet 4650DTN Printer Logo
165 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
