Open the case ( i take it your warranty has expired ) and check all connections, unplug the wires from the powersupply and plug them back in, when you try and switch it on, do any of the fans start spinning.. you probably have a dead CPU of motherboard..
Determine what CPU you have and borrow the same socket type from someone else if you can, slot it in and check, works = dead CPU
Good Luck
Cheers I will give this ago, thanks again
