Laptop Startup Hello mate, firstly thanks for taking the time to respond to my problem about my laptop not booting up. It is appreciated. I tried following the instructions you gave me and it boots up in safe mode but when I try to run C:\Windows\System32\Restore\rstrui.exe it cannot be found. I checked it and the only file in the Restore folder is one called "MachineGuid" or something similar - I can't remember exactly. I have Vista installed on my machine, could that be a reason for it? If you have any more ideas, I would be very grateful for your help. Many Thanks Shieldsy
  • Shieldsy67 Mar 20, 2008
    Many thanks Cropp, I really appreciate your time and help in this matter. I have thankfully got it working again. Fingers crossed it is a while before I need anymore help.
    Cheers again,
    Shieldsy
    New Friend:
You can find the solution on our site. click here http://devicearea.com/2011/02/11/how-to-fix-your-nvidia-graphic-adaptor-dumping-in-a-few-steps/
Posted on Feb 11, 2011
    Guru:
  • 377 Answers
Hi dear
oh so sorry to hear that
this methode for windows Xp
and let try this
Microsoft Windows Vista users Tip: If you are running Safe Mode because you cannot get into Windows you may want to first try loading the last known good configuration. Additional information about this mode can be found on document CH000626
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcment
Start Windows Normally
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver.
ok
cropp
Posted on Mar 19, 2008
  • Irwan Darmawan
    Irwan Darmawan Mar 22, 2008
    oke,
    dear, you're wellcome
SOURCE:
I own an ACER 4315 Laptop computer MS2220 Atheros AR5BXB63 with Windows Vista Home Basic. I'd like to partition the hard drive to run Ubuntu Linux. However the Ubuntu 7.04 Liveboot CD not recognized as a...
Hello there.
Nice to see more people trying out Linux :-)
From your description it sounds like the CD image you downloaded is not bootable. What i would do is scrap that CD and try the following, this is a guide that explains step by step how to take the downloaded .ISO file and burn it to CD, so that the computer can boot from it (known as a bootable CD).
Please click here for the information.
As Ubuntu has a partition program as part of the installer, you can use this to resize your Windows partition and install Ubuntu in the free partition left over.
This should get you setup in no time :)
Hope this helps.
Jul 04, 2008 | Acer Computers & Internet
My laptop has a problem which after start up and the desktop screen open, when i refresh the desktop, it will take long time and sometimes it said the windows explorer not responding.. and when i try to...
Yes, the problem is probably with the OS. Perform troubleshootings given in the following page.
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c01817290&lc=en&dlc=en&cc=uk
if the issue persists, perform startup repair.
restart the laptop and keep tapping f8 key.
select Startup Repair in available options.
hope it works.
Jul 14, 2011 | Compaq Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Windows freezes after startup
Its better to backup your data - booting from Ultimate Boot CD and backup to an external hard drive.
Try to do regular format or low level format to know the status of the hard disk
Feb 07, 2010 | HP Computers & Internet
Does not boot properly
Try running the diagnostics (Hold the Fn Key and press the power button or boot to the resource CD) See if the hard drive indicates and failure. If HDD fails, replace it. If it passes, then see if you can boot to safe mode (F8 at boot) and see if you can access windows there. If it does boot to safe mode, try MSCONFIG and edit the startup group and see if the system will boot normally in normal mode.
Other possible issues, fan failure causing overheating, or a clogged heat sink (Use compressed air to blow dust out of air intakes and exhaust) Virus and spyware
Sep 26, 2009 | Dell Latitude D810 Notebook
My hp pavilion zv5120 us is not booting
hey i can understand this first type run in search then type msconfig then mark application which is not needed in service and startup and in boot changed shutdown time to 3 second from 30 second who this help yu and also chang yur theme and dont use any screensaver since it also down yur laptop.and for any question yu can go to youtube and check got video over there.since it has helped me.
Apr 22, 2009 | HP Pavilion zv5120us (DZ329UABA) PC...
Laptop Won't startup Vostro 1500
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Vostro 1500 Notebook
Laptop
Hi, It appears that the your computer taking some time to login to windows. I suggest that when the computer finally booted successfully into Windows, you need to disable all the startup items under the system configuration.
Just type in "msconfig" under the "Run" screen and hit the enter key or click OK. Please click on the Startup tab then click on "Disable All" then hit "Apply" and "OK". You need to restart the computer to so that the settings will be updated.
Hope this helps!!!
Thanks
Sep 17, 2008 | LG CRN 8245B (CRN-8245B) Internal 24x...
Laptop will not respond..please help.
It is new and under warranty. Anything you do inside this laptop will void the warranty. Take it back to where you got it, and get it repaired under warranty.
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
177 people viewed this question
Ekse
Alun Cox
