Question about Acer Aspire 5610-4648 Notebook
Disc recovery management
I try to install the disc recovery the one that i made when my laptop came in
i burn 5 cd disc for backup then now my problem is i try to use this 5 disc it goes smooth when i installed it the problem is the last disc cannot installed because cannot be read may be because it has an scratch on it. how can you
help me about this problem now when i reboot my laptop the screen says that NTLDR is missing Press any key to restart. then nothing its happen it goes like this and this on the screen.thanks
    Scholar:
  • 135 Answers
NTLDR is a file that Windows XP needs to boot up, it is one of the first files your PC attemps to use when booting...
There are a couple of options available to you
The easiest being to take the laptop back to the supplier ( you didnt give any discription of the make or model ) and ask them to reload Windows XP. This should be at no cost if it is still under warranty )
Your second option will be to try and repair the CD...
Try the following, gently use toothpaste with a soft cloth and rub the disc in small circles, wash the disc off with warm water, dry gently and try the restore again..
Your third option is to try and boot of a Windows XP ( Same version as you had, either Professional or Home ( Borrow one from a friend, but do return it when you have finished )
Let the install run, it will come to a point where it asks if it should repair, select this option and run through the install...
Good luck !.
Posted on Mar 19, 2008
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
    http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
    Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
    This could be your HDD, failed. Work through, the troubleshooting procedures.
    Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
    May 14, 2010 | Acer Aspire 4315 Notebook
    I want to reset it
    Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
    Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
    Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
    Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
    Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
    Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
    Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
    If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
    http://www.vtechsquad.com/acer-support/
    Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
    How do I do a full recovery with the disc
    Turn your computer on.
    Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
    Change the boot device order to: CD-ROM, HDD in that order.
    Save changes and restart the computer.
    The Recovery Disk would boot up and a wizard will guide you through the recovery process.
    Follow the instructions to recover your computer.
    Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
    Reboot my Acer Notebook
    Mar 05, 2010 | Acer Aspire 3100-1405 Notebook
    I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
    This was taken straight out of the manual for your model, which can be found here.
    Acer eRecovery Management is a tool to quickly backup and restore the system.
    You can create and save a backup of the current system configuration to hard
    disk, CD or DVD. You can also backup/restore the factory default image, and
    reinstall applications and drivers.
    Acer eRecovery Management consists of the following functions:
    1 Create backup
    2 Burn backup disc
    3 Restore and recovery
    This chapter will guide you through each process.
    Note: This feature is only available on certain models. For systems
    that do not have a built-in optical disc burner, plug in an external
    optical disc burner before entering Acer eRecovery Management
    for optical disc-related tasks.
    When using Acer eRecovery Management, you may be prompted to enter the
    Empowering Technology password to proceed. The Empowering Technology
    password is set using the Empowering Technology toolbar or when first running
    Acer eLock Management or Acer eRecovery Management.
    Create backup
    You can easily create full and fast (incremental) backup images of your system
    configuration to hard disk from the main Acer eRecovery Management screen.
    Note: Fast (incremental) Backup is only available after a Full
    Backup is made.
    1 Press <Alt> + <F10> or select Acer eRecovery Management from the
    Empowering Technology toolbar to start Acer eRecovery Management.
    2 In the Acer eRecovery Management window, select the type of backup you
    want to create using Full or Fast.
    3 Follow the instructions on screen to complete the process.
    83
    English
    Burn backup disc
    Using the Burn Disc page of Acer eRecovery Management, you can burn the
    factory default image, a user backup image, the current system configuration,
    or an application backup image to CD or DVD.
    2 Switch to the Burn Disc page by selecting the Burn Disc button.
    3 Select the type of backup (factory default, user, current system,
    application) you would like to burn to disc. Choosing to burn a user backup
    will burn your most recently created backup image to disc.
    4 Follow the instructions on screen to complete the process.
    Note: Create a factory default image when you want to burn a
    bootable disc that contains your computer's entire operating
    system as it was delivered to you from the factory. If you wish to
    have a disc that will allow you to browse the contents and install
    selected drivers and applications, create an application backup
    image instead — this disc will not be bootable.
    The restore and recovery features allow you to restore or recover the system
    from a factory default image, from a user created image, or from previously
    created CD and DVD backups. You can also reinstall applications and drivers for
    your Acer system.
    2 Switch to the restore and recovery page by selecting the Restore button.
    3 Select the backup point you would like to restore from. You can also
    choose to recover the system from a factory default image, recover from a
    previously created CD/DVD or reinstall applications and drivers.
    Dec 20, 2009 | Acer Aspire 5720 Notebook
    What function keys do i press on startup to re insatll the operating system on my acer aspire 3690
    you can use the recovery disk which came along with the laptop to reinstall the OS. There is no function key to start the installation automatically, there is a backup / restore button in some laptops which can reset the OS. Check the manual for any such button on your laptop.
    Jul 07, 2009 | Acer Aspire 3690-2196 Notebook
    Used restore to another date, still locked in this process,
    Hi Linda,
    It sounds like the restore failed , try powering the PC off by holding the power button down for at least 5 seconds. Then reboot.
    Hopefully that will let you back into Windows, if you continue to have problems , try the following.
    Make sure you have your data backed up.
    Turn on the computer and when you see the white Acer screen fully loaded, press and hold Alt+F10 to do the reboot.
    This should start the recovery process from the recovery partition on your PC.
    If that fails , you will need the recovery disks, unfortunately , acer does not provide them and expects you to make them by going to Acer eRecovery Management's "System backup to optical disc" feature to burn a backup image to CD or DVD.
    Since you cant get into Windows , if you havent already made them , you need to order them from Acer.
    Yes they make you pay for them.
    You can order them here.
    https://secure3.tx.acer.com/RCD/Main.aspx
    Good luck.
    Mar 03, 2009 | Acer Aspire 5315 Notebook
    Cd/dvd drive problem
    Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
    Jun 04, 2008 | Acer Aspire 5315 Notebook
    Acer Aspire 5610-4648 Notebook Logo
    51 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
