Question about Apple iPod MA446LL/A MP3 Player
Ipod sound check doesn't work, songs all play at different volumes
  • 4 Answers
You should start by defining the songs where thee volume is abnormal and individualy right click them on your computer then go to the options tab and make sure they are set to "none" on the volume adjustment bar
Posted on Jul 20, 2008
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Posted on Mar 19, 2008
4 Suggested Answers
  • 51 Answers
SOURCE: mp3 output volume
The problem with iPod is that you just can't play music without iTunes. If you happen to delete the iTunes related folder on the iPod you will notice that you won't be able to play any of the files that are still there. (iTunes is the software that makes the iPod work).
On the other hand, you can surely drag and drop songs between your laptop and iPod (like Windows Explorer) ...and use the iPod like a portable Hard disk, but you won't be able to play any Music. So as it is, using iTunes is a must.
For varying sound volumes, you can use a technique called as "normalizing". There are a lot of tools available on the internet (free or otherwise) that let you normalize mp3s.
Search google for "normalize mp3".
Here is a Pointer:
http://www.bresso.com/normalize-mp3-making-song-volume-equal.shtml
Posted on Oct 17, 2007
  • 89 Answers
SOURCE: i can t play my ipod i just installed songs to it
  • I THINK YOU SHOULD UP DATE YOUR SOFTWARE.To update and reinstall your iPod software, first download the latest version of iTunes.
  • Next, open the new version of iTunes and connect your iPod to your computer.
  • Select your iPod in the source list and click "Check for Update" under the Settings tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
  • If this does not resolve the issue, try completely uninstalling iTunes and then reinstalling the latest version of iTunes
Posted on Mar 06, 2010
  • 268 Answers
SOURCE: IPOD NANO SONGS ARENT WORKING!!!
Test the songs that are not playing on the iPod in iTunes and see if the original file is still playable on iTunes if the song still plays re-sync your iPod could be when iTunes copied the song it must have failed or timed out, if that fails re-syncing try restoring you iPod Nano i have had this problem before and I just re-synced and it worked fine
Posted on Oct 18, 2011
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How do I normalize the Volume on my iPod Playlist
<p>The iPod revolutionized the way millions of users to hear their favorite music, whether at work, the gym or almost anywhere you go. The rich features and ease of use make the iPod of consumer devices the world's most popular electronics. However, one of the unique characteristics of the iPod is playing the songs recorded in his volume, so that some songs play louder or much softer than you want. The solution to this annoyance is resolved or normalizes the volume of all songs from an iPod playlist. <br /> <p><br /> <p>1. Connect your iPod by pressing and holding the "ON / OFF" and select "Settings" icon after the iPod was launched. <br /> <p><br /> <p>2. Select the "Music" menu option "Settings". <br /> <p><br /> <p>3. Turn the "Sound Check" option "OFF" to "ON". All music will now play a single volume, regardless of your recording volume. <br />
60GB ipod, no sound, rest appears to work. Have reset and restored. Checked sound levels. Thanks
I POD 60GB WAS PLAYING JUST FINE NOW ALL OF A SUDDEN IT JUST STOP PLAYING THE VOLUME BUT IT STILL DISPLAYS THE SONG NAME AND EVERYTHING ELSE
Jan 15, 2010 | Apple iPod Photo-60GB Power Hot Sync and...
Ipod turns on and works - cant hear song playing
Check the volume using the buttons on it and also in your settings/volume limit. If that doesn't work, resync it with iTunes and see if there is a parental control in place preventing music to be played.
Oct 13, 2009 | Apple iPod MA446LL/A MP3 Player
Test the songs that are not playing on the iPod in iTunes and see if the original file is still playable on iTunes if the song still plays re-sync your iPod could be when iTunes copied the song it must have failed or timed out, if that fails re-syncing try restoring you iPod Nano i have had this problem before and I just re-synced and it worked fine!
Aug 26, 2009 | Apple iPod nano
Vinyl ac'97 sound No sound!
please check if the Audio cable is on the right port.also check the Volume Level weather its in Mute.Also Check if ur Speaker si working or Power to Check Weather the Speaker is Working Just use a Different Power Source like MP3 player or Ipod.if no Sound frm the Speaker then it Time to getr new Speaker.Adios
May 16, 2009 | Computers & Internet
Ipod Video 80 gb loads song but does not play
You might just have to convert the songs into a format that the ipod can read and play. Under itunes, just right click on a song that does not play on your ipod and click on the convert to mp3 option. Then transfer the converted songs to your ipod and it should work then.
Nov 17, 2008 | Apple iPod MA446LL/A MP3 Player
Usb/ipod-no sound
Sounds stupid but did you turn up volume on ipod?
Aug 04, 2008 | Car Audio & Video
Mp3 output volume
Here is a Pointer:
Oct 17, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
