Question about Minolta EP4000/5000 CS/PRO Copier
Service minolta ep 4000 cs pro serial no 2143978 it said maintainace time and the maintance code m 2
  • Anonymous Mar 14, 2014
    les boutons sont en vert mais rien ne fonctionne si j'appuis
After replacing the waste toner bottle you must reset the waste counter(in copier maintenance mode) to make the error go away.
Posted on May 21, 2008
  • 82 Answers
It means it time for the cleaning web, and waste toner bottle to be replaced. once you replace it you can reset the indicator.
thanx,
mikey
Posted on Mar 24, 2008
SOURCE:
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 18, 2012 | Minolta Office Equipment & Supplies
Minolta ep 4000 Copier shows: Call Maintenance M4
stop 0 stop1 sets the machine service mode. select consumable clear the copy kit counter
Mar 31, 2012 | Minolta EP4000/5000 CS/PRO Copier
C 0040
C0040 is a cooling fan failure code. Opening and closing the front door wil reset the code. Doing this while "bumping" the machine will restore the machine to operational MOST of the time. Cooling fan replacement will eventually be required. Resetting though can be accomplished in most cases.
The part number for the fan is 9313-1310-61 and here is a picture of the fan which is located behind the rear cover.
Jun 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
How do i install my CSPRO 4000 printer to my computer?
The EP4000 is a Minolta analog copier. it has no computer connection.
Jul 02, 2009 | Minolta EP1083 CS/PRO Copier
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to [email protected]
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Services
what kind of problem are you having, please be as descriptive as possible.
thanx,
mikey
Mar 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
Service
Can you be more specific ?????
Thank you !
Document jams ep 4000
Ceck the rubber rollers on the doc feeder. They are probably real soft and mushy. If so they need to be replaced!
Dec 14, 2007 | Minolta EP4000/5000 CS/PRO Copier
289 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
