Question about Panasonic DMR-EH75 DVD Recorder/VCR/HDD Recorder
Sharp HDD DV-HR300
Hi
Does anyone know what is the format of the hard drive for a Sharp HDD/DVD recorder the last Hard Drive failed purchased a new hard drive but can seem to format it.
Thanks in Advance
Mark
  • 61 Answers
SOURCE: Not completing recording from HDD to DVD
DVD's are burned from the center out, so if you're seeing a small band at the center, it sounds like the laser is overheating and quitting very early in the burn process.
No idea how to fix it, maybe blow it out with canned air?
Good luck, sorry I can't help more.....
Posted on Jan 27, 2008
SOURCE: Panasonic DMR-EH75V DVD Recorder
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Posted on Apr 02, 2008
  • 360 Answers
SOURCE: Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Posted on Feb 08, 2009
  • 4090 Answers
SOURCE: my Panasonic DMR-E85H DVD Recorder's hard drive
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
Posted on May 13, 2010
Testimonial: "Thank you."
  • 8457 Answers
SOURCE: Does my Sharp DV-RW34OU dvd recorder+vcr have
Ur Sharp DVD Recorder/VCR combo have any HDMI ports.Yes,Tries websites like Amazon.com,Ebay.com to buy a Digital microphone use the HDMI port it work fine.No tries researches buy the analog microphone.Just ask the vendors info.for the device functionable or compatible to ur device.
Posted on Jul 12, 2010
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Recording a dvd to the hard drive
look for an option in the DVD menu for dubbing this means to copy contents to hdd (usually cannot do it with copy protected discs but will be ok with a disc you made yourself)
Aug 30, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
No hdd found...
Hi.
Most new hard drives are not partitioned nor formatted and therefore are not ready for use when first bought. They have to be initialized/prepared for whatever device they will be attached to. Formatting may be FAT, FAT32, NTFS and others.
This could be done using a PC where the hard drive (HD) could be initially/temporarily installed as a secondary master/slave and use the Operating System to partition and format making it ready for use. Alternately, an external casing with USB interface may be used.
For your purpose, you need to determine in what format will your digital video player/recorder accept the new HD. This may be found in the manual. Alternately, some digital video player/recorder has this feature/option that will allow you to format newly attached to HDs.
Should the above be not sufficient, please post back with the brand and model of your digital video player/recorder.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Western Digital Caviar WD400JB Special...
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
Recording from Hard dive to Disc
You can download a copy of the user manual from the Panasonic website .
To copy files from the HDD to a DVD disc, insert the DVD then press 'Functions' on the remote. From there select the 'Copy' feature and select the items you want to copy. There is also an 'Advanced Copy' available in the 'To Others' menu.
Dec 18, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EH75 DVD Recorder/VCR/HDD Recorder Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
