Question about Carrier 38CKC036 Air Conditioner
Suction line frezzes up every three or four dats
UPFLOW/DOWNFLOW PRIMARY AND SECONDARY DRAIN, CONDENSATION HOLDER FILLS UP AND AIR CONDITIONER SHUT OFF. I HAVE TO DRAIN PERIODICALLY.
Posted on Jun 12, 2008
  • 236 Answers
Check your air filter and evaporator coil if clean, but if its clean then may be the unit is under charge and need to recharge freon.
Posted on Mar 19, 2008
I have a 2001 Tahoe & i cant find the four season suction ac line . I have rear ac but the one they show for my truck isnt right...
******* A/C pipeline is bigger than the discharge pipeline. I believe your ******* pipe size should be 1/2 inch and your discharge 3/8"
Hope this was helpful
Regards
Jun 09, 2016 | Miscellaneous
I have an Electrolux dryer with a four prong cord, and have moved to a house with a three prong receptacle. The dryer appears to have an integrated grounding strap connecting the frame to the center...
Connect the three-prong wire you have the way the same wires (Line 1, Neutral, and Line 2) of the four-prong wires are connected to the terminal block then connect the integrated grounding strap to the Neutral (center) terminal.
Jul 16, 2011 | Washing Machines
My ps3 frezzes after 20 minutes of playing games or watching movies tried reseting system several time
Sounds like overheating, if you have a suction type hoover try using this to clear fan vents, they are also prone to cigaratte debris if you are a smoker, in which case you need to take it to a repaier to clean out.
hope this helps, but your problem is most likely overheating is some form.
Mar 19, 2011 | Sony Playstation 3 (PS3) Console
Foodsaver pro locked up. 3 green lites blink off and on. is the problem fixable?
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
Oct 17, 2010 | Tilia FoodSaver V2240
There is a line with with wrappin on back of ref that is frezzing over wht is wrong
That is typically a sign of a problem with the heat exchange, specifically the suction line and capillary line have separated OR...the system has been worked on recently and been over-charged with refrigerant.
Answer me these questions...
Is it frosting up close to the compressor ? Where it comes out the back wall at the top back corner only ? Or the entire line all the way down to the compressor ?
Has this fridge had any system work performed on it recently or has anyone "topped it up" with refrigerant ?
What are the temperatures in the fridge ? Are you capable of gauging/measuring system pressures ?
Finally, how old is this fridge and do you know if it contains R12 or R134A ? ...if it`s old enough for R502, forget it ha ha !
I`ll watch for your reply.
macmarkus :)
Jun 22, 2010 | Kenmore 64802 Top Freezer Refrigerator
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Couldt find_ds_menu.dat
Do you have your DS set on Auto Mode, if so the DS will automatically start up any games that are inserted.
Deselecting Auto Mode:
If it's on Auto Mode, any games are automatically started. To deselect auto mode you just need to start up your DS without any games in either of the game slots, then it'll go to the DS screen, since no games are in for now this screen is useless right?
To select Manual Mode ( where it goes to the selection screen ) as your preffered setup, you'll see a small icon of what resembles a DS at the bottom of the menu screen. Remeber your games are still not inserted at this point yet. Use the directional pad to select the mini icon, or you can tap it twice. Tapping it proves more difficult though due to it's position. Once selected a toolbar of four options will appear, tap on the one displaying a wrench. From that box three other options should appear, tap on the one shown as an arrow pointing halfway through a rectangle (start up settings) you want to select Manul Mode. Wait a few seconds for the DS settings to save then you can turn it off. Now you'll be able to see the selection screen with your games inserted.
Summary of all that:
  1. remove any inserted games
  2. turn on to see the menu screen
  3. select the mini DS icon at screen's bottom
  4. when the four pictures appear, tap on the one of a "wrench"
  5. when three more pictures appear tap on the one of an arrow pointing half way through the rectangle
  6. two options appear, select manual mode.
I really hope thats what you meant ^_^ If it wasn't, ask one of the experts.
Dec 30, 2007 | Nintendo DS Lite Console
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Carrier 38CKC036 Air Conditioner Logo
88 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
