Question about Motorola Mobility L6 Cellular Phone
MotoL7 my brother opens any application that i lock in just 5 seconds.even if i change the code he still opens everything in just one try...; ( .i think there is some secret way or a master code which opens any locked application...pls help me : (....
    Brigadier General:
  • 7,752 Answers
Just change the security code from 000000 to another code that only you know then he would be able to get into it.....remember chnage the security code not unlock code.
Posted on Mar 19, 2008
How can i change factory reset number so no one knows how to open up the freestar van 06
There is no way to modify the factory programmed number, but if you want to change from that one to your own programmed number, do as follows;
  1. First enter the manufacturer's code. Doing so will unlock the driver's door.
  1. Next within 5 seconds depress the 1*2 key on the keypad. This will cause the locks to lock then unlock.
  1. Enter your new 5-digit code. Each digit of the 5-digit code must be entered within 5 seconds of each other. Once entered, give it a second or two for the codes to register. You'll know they registered once the car locks then unlocks.
Feb 24, 2017 | 2006 Ford Freestar
How do I change the keyless entry code for 2000 mercury grand marquis
1.locate and enter the factory set code(taped to the computer module also located on trunk lid. 2.press the 1/2button within 5 seconds of step 1. 3. enter your personal 5 digitcode within 5 seconds. Allthedoors will lock and unlock to confirm programming of the new code.
Apr 02, 2014 | 2000 Mercury Grand Marquis
Hello i have forgot my lock code for my nokia N76 and my IMEI is 352054/02/114169/3 please urgent
Don't FORMAT the phone until you have tried everything. Default Nokia lock/security code is 12345, it's always a 5-digit code, so even if you entered a new lock code consisting of 6-digits, it will only save the first 5-digits. So try 12345 first, if not, try to remember if you changed it, and used ONLY the first 5-digit of whatever number code you used.
Nov 27, 2013 | Cell Phones
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Jan 02, 2013 | Cars & Trucks
How to lock my pictures
Once you have jailbroken your iPhone. You'll got a Cydia icon on your SpringBoard.
  1. Launch the Cydia.
  2. Go to Search Tab and search for Lock Down and tap it.
  3. Tap Install button at Top-Right and then Confirm button at Top-Right to begin installation.
  4. After completion, go back to Springboard where you'll find a brand new icon i.e. LockDown.
lock-iphone-applications-lockdown-01-165x240.jpglock-iphone-applications-lockdown-02-165x240.jpglock-iphone-applications-lockdown-03-165x240.jpg
lock-iphone-applications-lockdown-04-165x240.jpglock-iphone-applications-lockdown-05-165x240.jpg
How to use LockDown
  • When you will run the Lockdown application for the first time, you will be asked to setup a Safety Code and a Password. This password will be used to unlock any locked application and to open Lockdown itself. Safety code is useful in case you forget your LockDown password.
  • Once you have setup the Password and safety code, you will see all your iPhone applications listed on next screen.
  • Select any application you want to lock, a Lock button will appear. By tapping that button your selected application will be locked and a little lock icon will appear next to that locked application.
  • Now if you close LockDown App and try to open you locked application (Mail app in this example), you will be prompted to enter the password to open it. Use your Lockdown password to open that App.
(Once you open the app, use it and when you close the app it will be automatically locked again. So no need to re-lock it in LockDown.)
lock-iphone-applications-lockdown-1-165x240.jpglock-iphone-applications-lockdown-15-165x240.jpglock-iphone-applications-lockdown-06-165x240.jpg
lock-iphone-applications-lockdown-07-165x240.jpglock-iphone-applications-lockdown-08-165x240.jpglock-iphone-applications-lockdown-09-165x240.jpg
Lets check other options in Lock Down.
  • Tap LockDown to launch it. This time you'll be asked to input the password to open LockDown. Do it.
  • Tapping any locked application in LockDown will prompt you if you want to Unlock it. Pressing the Unlock button will perform the unlock that App.
  • Locked Applications button at the top right quickly shows all the locked application only rather scrolling through all applications to locate locked ones.
  • Under Settings tab at Bottom, following options are available:Locking Options
    • Lock All Applications
    • Unlock All Applications
    • Lock This Application (ON/OFF)
    Password Management
    • Change Saftey Word
    • Change Password
    • Forgot Password
    Other Settings
    • Lockdown Dylib (If you turn it OFF, even if you open a locked application it will not prompt for password. So, it's helpful when you are using your iPhone by yourself. See the details in screenshot. )
    • Lock Icon Moving (When turned ON it do NOT let anyone to move any icon to preserve your arrangement of icons.)
    • Lock App Deletion (When turned ON it do NOT let anyone to delete any application without your permission.)
    • Enable Launch Button (When turned ON, Lockdown will show a launch button when you open a locked application and input password.)
lock-iphone-applications-lockdown-10-165x240.jpglock-iphone-applications-lockdown-11-165x240.jpglock-iphone-applications-lockdown-12-165x240.jpg
lock-iphone-applications-lockdown-13-165x240.jpglock-iphone-applications-lockdown-14-165x240.jpglock-iphone-applications-lockdown-16-165x240.jpg
I am using this great application since the day it's supported with iPhone OS 3.0. It's working like a charm and will keep it installed because of its usefulness and surely recommend it.
May 13, 2011 | AT&T Lands Phones
Sir how can i unlock security code in the applications
if you know the unlock code of your Motorola,
goto
menu---> settings---->security---->lock application
here you can choose which application should ask for unlock code when they are opened.
in case you want to change security code, go to
menu---> settings---->security---->new passwords, here you can change the unlock code
if you dont have unlock code then visit nearest mobile repair shop and they will reset the code in matter of seconds.
Mar 29, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Change battery everything gone dead will not take land rover disc
Firstly, pop a new battery in the fob.
Now we can enter the EKA.
Close all the doors.
Turn the key in the driver door lock to the unlock position and hold there for at least 5 seconds until the alarm sounds once. Then return to centre - always ensure you return to centre and do not delay more than 10 seconds between turns, or hold in the position for more than 5 seconds or you will reset to the start. Turn to full extent of travel.
1st Digit turn to unlock the number of times specified.
2nd Digit turn to lock the number of times specified.
3rd Digit turn to unlock the number of times specified.
4th Digit turn to lock the number of times specified.
Finally turn to unlock once more. If it is correct a double bleep will sound (single bleep is incorrect code)
You now have a 5 minute delay - don't open any doors. The anti-theft indicator will continue flashing once every 2 seconds for the five minute period. When this goes out, open the door and start within 30secs.
After 3 failed attempts, the security system invokes a delay period of 10 mins during which the system will not accept any further attempts to enter a code.
Jan 18, 2010 | 2004 Land Rover Discovery
My brother gave me his Nokia N92 cellphone. I
This link will help you to calculate lock code with imei no.http://www.nokialockcode.com/calculate.php.Rate me if it was helpful.
Oct 28, 2009 | Nokia N92 Cellular Phone
Nokia E90 forgotten lock code
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3
Unlock Security Code using Memory Card
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
Dec 15, 2008 | Nokia N70 Cellular Phone
MOTOROLA V360 UNLOCK CODE
u can't use unlock code to reset the mobile, u need security code
Apr 09, 2008 | Motorola Mobility V360 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
