HELP PLEASE I WANNA WATCH A FILM BUT I CANT
IN MY CAR DVD PLAYER WHEN I INSERT A DVD IT STARTS SLIDING THE DISC INTO THE PLEYER AND IT JUST RETURNS IT THE MOTOR SEEMS TO BE WORKING IN IT OK BUT THE DISC ONLY GOES IN HALFWAY AND THEN IT JUST RETURNS IT IS NOT ONE OF THE DVD PLAYERS WITH A DRAWER THAT SLIDES ITS ONE WHERE THE DVD JUST SLIDES INTO THE MACHINE
  • 11 Answers
These address a DVD player that ejects a disk it cannot "read".
1) The lens is dirty (don't blow in it, you look nutter and it does nothing to clean the lens,it just adds moisture to the unit).
2) Your transport slides are impeded some way or needs lubricant.
3) You have a scratched or incorrect format of disk.
These relate to damage:
1) You dropped or Jarred something critical in the transport, and the Lens isn't aimed correctly.
2) There is damage to the clamp, where a disk is not seated properly.
3) The drive motor has worn out, lost a winding, or cannot reach the appropriate spindle speed.
In any case you could open and spray canned air in the unit and see if you can make it work, although this is doubtful to work. More than likely you need to consider replacement or professional servicing.
Any optical based electronics need periodic cleaning and lube. You can minimize this by keeping dust from the unit with regular exterior cleaning. It is the dust that ruins the lube job on the transport slides.
Lastly, does it do this with ALL DVDs? Some are formatted differently and might not be readable by your player.
Hope this was helpful!!
-Gretchen
Posted on Mar 22, 2008
  • 594 Answers
Are you in park? I dont believe these players are designed to work unless you are stopped in park or just in the ACC key position, I dont know how they know, but that is how they are designed for safety, Are you sure the DVD is label up, maybe it takes it the other way, try a cd.
Posted on Mar 20, 2008
SOURCE:
A DVD is stuck in the player and the door will not open, it makes a grinding noise when you try to open it.
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
  1. unplug the device (dont wanna get electrocuted)
  2. remove the screws to the back and under the player
  3. lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
  4. you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
  5. remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
Apr 05, 2011 | Oritron Televison & Video
I CANT PLAY A CD OR DVD DISC
you would need to enter your navigation cd first before your able to play any cd or dvd's
Jun 06, 2010 | Pioneer AVIC-N2 DVD Navi Rcvr with 6.5"...
Unaible to down load vidio data from canon dc310 to my pc
Try to copy directly Your camera disc to conventional DVD, without downloading files to computer. It is possible with Nero Burning Rom in a disc copy mode. And before it, try to play an original at Your DVD player, or from the camera direcly to TV. If it works, then make a direct copy as well. Another solution is insert original dvd to computer and copy all carpets directly from dvd to HDD. Then, using MPEG Streamclip (free program) test Your files. If You can see the image - perfect. Any video can be converted a DVD format without problem.
Sep 06, 2009 | Canon DC310 DVD Camcorder
Cant play dvd cd or even eject the disc that is already in .
actually it is due to faulty disk or dirty lens sometimes , when the lens is dirty it keeps on trying to read the data from cd or dvd and it just cant stop that infact stuck in it , or the other reason is faulty loading gear , in either case u have to physically dis assemble the player , remove the top cover some 4 or 6 screws are there in place open the top cover see the cd /or dvd and remove it physically do not force anything hard when removing the media and then if u can see the lens of ur player just clean it with a soft cloth with ur fingers in cicular motions very gently and u will see that it will play dvd /cd fine , the other thing if the loading gear is faulty or broken then u can ask me more on this
Pls rate me WELL !
Jul 04, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Unable to play my brand new wii fit
I was just being really thick!! Eventually I found the right button on the remote and there it was on the screen. Thanks anyway though, and I know where to find you again. Sure I will!
Apr 14, 2009 | Nintendo Wii Console
Eclipse avn 2454
you need the map disc, the map disc has the security key on it.
Jun 28, 2008 | Eclipse AVN5500 Car DVD Player
Insignia roof mount DVD player for car wont read disc
My Necvox RE9269 Dvd Player Starts And Then Stops In A Moment Then Displays The Message 'NO DISC' Can Anyone Help Please
May 13, 2008 | Car Audio & Video
Dvd disk won't eject???
this is device do not play dvd-video, onli dvd-rom with maps for gps-navigation.
Apr 28, 2008 | Eclipse AVN5495 Car DVD Player
Dvd pleyer protron pdv-288
What is the code for setting the DVD player to InteracTV by Fishers price
Mar 09, 2008 | Televison & Video
Parental screen coming up on a DVD. Not able to watch DVD.
use password 3308 to change the parental control to 7, and the movie will run
Feb 14, 2008 | GoVideo DV2150 DVD Player/VCR
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Ekse
