Question about Labtec LCS 1024 Computer Speakers
Labtec LCS 1024
Im looking for a internal wiring diagram for Labtec LCS-1024 I have four disconnected wiring color is 2 red and 2 black i only want to know where do i connect them.
Do you have any schematic of Labtec 1025 with wiring conection? Thank you for your response it does help me alot
Posted on Mar 29, 2008
    Scholar:
  • 70 Answers
I don't have a wiring diagram for you but can tell you this as standards apply.
Red is always the positive (+) terminal and black the negative, ground, (-) terminal. FYI-though people use the term ground it is not correct.
Another thing you should know is red and black are relative. Inother words, when red to red and black to black it will cause an outward motion of the speaker. If you happen to reverse them, red to black, it just causes an inward motion of the speaker. Sometimes this is refered to as the "phasing" of the speaker.
Speakers are usually marked at their connection points with a red dot or a (+) for the positve and a black dot or (-) for the "negative" side.
So there's nothing to worry about if this happens anyway except:
if you were to go red-black on one speaker, and red-red on the other. This will cause the speakers to be in series which normally wouldn't hurt things, but make sure it's not done just in case you amp section cannot tolerate this condition.
Hope this helps.
Jeff
Posted on Mar 21, 2008
I need a COLOR wiring harness diagram for john deere la130 riding landowner. i do not have manual. need to know if im missing any parts. i need to know where the colored wires go. -red -red & black...
ok i found a picture diagram for what looks like to be your harness but i you need to get the numbers off the wireing harness its self
these can be very helpful in locating the proper diagram and wireing instructions for this harness
now the pictures and color codes is on a picture at bottom of the link i put in here so hope the link helps youll have to zoom the pic
there is two types of harnesses with the four points (meaning ends)
one is for the clutch and one is for back panel behind steering wheel the guages red is always hot red and black striped is key accessorie hot
yellow is usually the on position once key starts to engage blades or clutch
the blacks are grounds
need a good pic of this harness with out hand in way and closer but showing all the end points ive worked on these but i would rather see it better with more pics if possible
Nov 09, 2013 | Cars & Trucks
Opening Labtec speakers type LCS-1030
To open these you need to pull the front grille off. There are four screws, one in each corner. You'll need to do a bit of prying to get it open as the case is sealed around the edges, but it isn't too terribly difficult. Just take your time.
Mar 03, 2012 | Labtec LCS 1030 Computer Speakers
Not sure what the wires colours are
We dont either. You need to post what you are trying to connect. Amplifier? Sub? Speakers? Head Unit im sure. But you need to look for the radios wiring diagram.. Today's radios are generally basic with the color scheme. Black is ground. Red is switched power. Yellow is constant power. Orange if for dash illumination... Speakers are usually 4 colors. 2 wires a speaker. For instance Front Left would be White/Black-Stripe. White being the positive and black strip being the negative. Usually the four main colors for the speakers are White......Gray.......Purple..... Green... with the striped wires going to the negative on each speaker. Blue wires are usually for power antennaes or also used to send trigger signal to the amps to turn on and off.
Jul 11, 2011 | Car Audio & Video
I have no power supply cord for my labtec lcs-1030 speakers- what do i replace it with? i cannot find specs for it anywhere online
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Labtec LCS 1030 Computer Speakers
Where can I obtain an internal replacement speaker for Labtec lcs-1024?
GO TO EBAY AND SEARCH LABTEC SPEAKER. YOU'LL FIND ONE
Dec 11, 2010 | Computers & Internet
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Jun 21, 2009 | Labtec LCS 3210 Computer Speakers
Installing Labtec LCS 800 speakers
1 wire goes between the 2 speakers
1 wire goes from the speaker with 2 jacks in it to the computer, the back of the computer should have a green port to plug in the cable to
1 wire is the power
this is a guess without seeing your setup
Feb 17, 2009 | Labtec Audio Players & Recorders
Schematics
Dclf1
Good day!
First things first:
1) you only can find those schematics on
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
but have to call or email support.
hope they can send the info.
Open Sky
Feb 09, 2008 | Labtec LCS 1024 Computer Speakers
Labtec LCS 1024 Computer Speakers Logo
372 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
