Have a ONKYO 787 with distorted sound repairer said sound prossesor faulty not worth fixing, l paid $2700.00 for the amp and was great wile it worked, can anyone help
  • jimpalantzis Mar 20, 2008
    thanks for that quick response its the best news lve heard today
  • 4,234 Answers
Some models of Onkyo had problems with memory chips on the DSP boards (digital processing). Replacing these chips usually resolved the problem. These chips are surface mounted and are not the easiest to replace. This should be done by a trained tech. Expect this type of repair to run about $150-$200.
Dan
Posted on Mar 19, 2008
No sound from speakers or headphone jack at any volume setting; current use in TV mode. Video works correctly.
hi sounds like the sound prossesor or the amp ic could be faulty may have to replace the mainboard to cure the fault, thanks
shaun
Feb 10, 2017 | Televison & Video
Technics SU-G91... clipped out @ high volume. Disassembled, sleaned and applied new grease to heat sinks. Amp worked great for a while, clipped out and now occasionally will not light up the front dis
First off, why do you drive the amp into clipping? It's not good for amp, nor your Klipsch. We won't even mention the terrible load that Klipsch in parallel presents to your amplifier, nor the distortion. I would suggest to you, that the amp goes into thermal overload. Trying turning it down by 20-30db, and see if it stays on-line. It can be fixed, if turning it down doesn't help, it can be repaired, but not inexpensively.
Nov 27, 2014 | Technics Audio Players & Recorders
TX-SR803 with no sound or popping hissing on any input
It is common for a short term power surge to open up the internal fuse in the main power transformer. Without testing some components inside the unit, I really can't say for sure whether or not the unit is worth repair. I would suggest that you invest in a detailed repair estimate at an authorized Onkyo service center.
Keep us posted.
Dan
May 26, 2009 | Onkyo TX-SR803 Receiver
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
Distorted right channel
There is a problem in the pre-amp section of the receiver. This is most likely a bad transistor. FIgure on about $5-$15 for parts for this repair.
Dan
Sep 11, 2008 | Onkyo TX-SR600 Receiver
Yamaha RX-V660 right channel gone
Try checking the connections.
If your really value your receiver it would worth it.
Jun 22, 2008 | Onkyo TX-DS575 Receiver
Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Jun 14, 2008 | Onkyo TX-DS787 Receiver
164 people viewed this question
 Grubhead
Grubhead
