Question about Canon PC-920 Black and White Copier
Hi. i have the save problem with my canon Mp180, when i open her it shows me after 2 minutes the Service error 5100, and the button on/off is flashing, and i can't do nothing with her....the answer that you give to her it working? please help me too....give me...an answer what to do with her.. thank....
This can be one of a few things. None of which are considered
a user repair.It is a carriage error. So the things to look at are the carriage, encoder strip, logic board, or carriage motor. More times than not it is a logic board issue.
Posted on Apr 15, 2008
    President:
  • 4,402 Answers
Just go to canon.com and select support and search error 5100
please mark the post as fixya
Posted on Mar 20, 2008
SOURCE:
Error 5100
Issue: ERROR: Service error 5100 appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP180 may require repair
Try the above..
Oct 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I have canon printer pixma mp180 its showing code 5100
just go to this link........
1) http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
2) http://www.fixya.com/support/t571350-error_code_5100
Jan 07, 2010 | Office Equipment & Supplies
Error code 5100 is coming up on my printer, what do i need to do please
this error is becouse of waste ink
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Dec 02, 2009 | Canon PIXMA MP180 All-In-One InkJet...
An error code of 5100 has appeared on my canon pixma mp180 printer - what do i need to do please?
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Nov 17, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
Jun 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 on my printer cannon ip 1700
por favor necesito ayuda para una impresora cannon mp180 despues que la mando a fotocopiar y va a tomar la hoja me sale el error (servicio impresora 5100) les agradezco me estan atacando
May 04, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Canon mp180
I had this problem. Removed both ink cartridges and carefully wiped the contacts and print nozzles with a tissue. Re-inserted cartridges and printer now works perfectly.
Good Luck.
Feb 20, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PC-920 Black and White Copier Logo
66 people viewed this question
Clive
Clive
old marine
old marine
Ekse
