Hi 1. Does anyone know
1. Does anyone know what is the maximum ram a P4145 G.V
motherboard can have?
2.Whatis the fastest cpu can the motherboard take?
  • 1,665 Answers
Hi Have a nice day!
1. Memory
Max. 2GB DDR
2 x DDR slots, DDR333/266
2. CPU Socket 478, Intel Pentium 4( Northwood/Prescott )/Celeron
FSB 533/400 MHz
If you need any other info youre welcome.
Posted on Mar 19, 2008
Can a Toshiba p15-s409 be upgraded to another motherboard and processor?
Motherboard is usually a big no when it comes to laptops as that motherboard was specific to that laptop. That is the way they are made. It will support a max 2GB of RAM, according to the specs.
The CPU? Well it depends on if, and that is a big if, the motherboard will support a faster P4 proc. I believe the fastest P4 that was made was 3.8Ghz, but have never found one. Then will the motherboard support a proc that fast? You have to look at the heat/cooling issue also.
If you don't want to get a new lappy, and don't have 2GB of RAM in it, then get more RAM. A 2.8Ghz with 2GB of RAM will run Win 7 fairly well.
Mar 22, 2014 | Toshiba Satellite P15-S409...
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
1024mb ram
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
I have a Pentium 4 1.7Ghz 478 socket 400mhz CPU in my Ps4800d-x motherboard. I want to upgrade to a faster processor. There are 3.2Ghz & 3.4Ghz available. But is there a maximum size I can install?
Open the link provided. These are the CPU's the motherboard can run.
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1) is the fastest CPU listed. The 1MB cache makes this CPU the fastest of the bunch. You may need to flash the bios in order to run this CPU. Click the Go button to the right of the CPU listed to update you're bios if bios version No# 1006.002 is not installed.
Mar 31, 2010 | ASUS P4S800D-X Motherboard
Motherboard P4VMM2 has 4 slots, 2 are empty, 2 have memory cards of 128 MB RAM each. What is the maximum RAM that it can support?
2 GB of memory, You can configure those anyway you'd like, however, the best pratice in memory is to match your chips for best proformance.
Good Luck,
Feb 17, 2010 | EliteGroup P4VMM2 Motherboard
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Is their a special make of memory card, ie: ddr
According to:
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
Sep 15, 2009 | Foxconn 400M01-G-6L Motherboard
Gigabyte GA-60X Memory upgrade.
Hey syconus, Matt here- It will unfortuatly still only take the 512mb because it is not compatible with the new memory. Sorry:|.
Dec 31, 2008 | Gigabyte GA-6OX Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
