Hello.
You must se up your printer.
Connect it to a PC and you have to download the drivers/software from the CD provided.
OK, now if you want to print document such as Microsoft Word, you can just press print and it will print.
If its image, double click on the image, you'll see the print and click on it.
**If you still can't print, go to control panel, click on Printers and other hardwares, then click on installed printers/faxes (it might be that there are more than one option of printing and it did not locate the right place), so check if you can see your printer there. If your printer is offline, double-click the mouse and set it as Default Printer.
That should be it.
If that does not help, you can view the manual here.
Hope it helps.
