Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I lost my instruction manual to my hooversteamvac and need to know how to hook up the upholstery tool
  • 438 Answers
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
Step 4. Replace panel with converteI lost my instruction manual to my hooversteamvac - 2b79b23.jpg>Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tubI lost my instruction manual to my hooversteamvac - b95cee8.jpg onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Posted on Apr 15, 2010
  • Duckie47 Jul 10, 2011
    Thank you! I spent a couple hours trying to figureout how to get my stair cleaner turbo brush to work and even got motion sick watching a UTube demo. Afte a short nap to settle my stomach, I found you and I was cleaning in minutes! Thanks again!
Lost operating instructions - need basic instructions
If you go to www.Hoover.com, , on the lower left you will find a link to download manuals. Put in your model as instructed.
Feb 26, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
How do i attatch the upholstery cleaner for the hoover f5835 900
The instructions for the cleaning tools are included in the User Manual. Please download or read it from:
http://www.hoover.com/pdfs/manuals/F5835900.pdf
The Upholstery Cleaner requires the hose be connected to the recovery tank, and the tool be slid onto the hose end.
Oct 12, 2009 | Hoover F5835900 Upright Steam Vacuum
Lost suction after empting the tank,wasworking but now not!!!!!!!
This cleaner uses no belts. Check these items:
(1) Is the lid sealed to the recovery tank?
(2) Is the rubber seal in place under the hood. There must be a rubber seal on the round tube that connects to the bottom of the recovery tank when it sets in to the cleaner base to connect the vacuum to the tank.
Aug 07, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do i connect upholstery cleaner to kirby sentria
Below is a link to the GoodVac.com website. This link will take you to the "Online Kirby Vacuum Manual". The manual will instruct you in removing the carpet nozzle, replacing it with the hose and attaching the upholstery tool.
http://www.goodvac.com/articles.asp?id=135
Jul 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hook up upholstery hose, lost manual F5915-500 steam vac
Yes, I did figure that out. That would be 9.99 first, please and I would be more than glad to post the solution.
Feb 07, 2009 | Hoover V1 SteamVac SpinScrub Vacuum
NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Dec 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
651 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
