Question about PC Chips (M925G) Motherboard
To connect a unit with a computer 1km away..
I want to coneect a metereological data receiver unit with a pc which is 1km away from the receiver.the output of the receiver unit is cat 5(RJ45).
now the interconnecting cable i have to use is a phone cable(2 wire twisted pair).
can this connection be made using a ADSL modem.
if yes what are the configuration for the modemthat i have to make.
thnx
There are easier ways of doing this. If you simply want to extend the length of the Cat 5-e cable they make simple connectors which do so. You must make sure the cable is a STRAIGHT SHOT cable and not a crossover cable though. A wire tester would work to look at the configuration but you can look very closely to the color coordination inside the connector and figure out which configuration the cable is. If the colors are int he same order on both sides then you have a straight shot cable.
Posted on Mar 25, 2008
My garmin nuvi50 not conect with the computer
Does the unit boot properly to the main menu? The subroutine that scans for a PC to GPS data connection only can occur at the main screen. Does the USB port appear to be loose? bad connection at the USB port will prevent the PC from linking up to the Nuvi.
Oct 28, 2013 | Garmin nuvi 885T GPS Receiver
710 frozen on tom-tom splash screen
1. Activate the TeleType GPS program
2. Select Tools>GPS Status>Status.
3. Look closely at the GPS output that is displayed in the View Status menu. Data should be flowing even when the GPS receiver has not locked in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select the Satellites tab (Tools>GPS Status>Satellites), and watch the satellite signal strength
Nov 27, 2007 | Tomtom GO 700 GPS Receiver
I cannot use my garmin 300t whilst it is plugged in charging, it just shows a page with what looks like a computer tower, a cable and a satnav. i cannot navigate away from that screen
The power cable used to charge the unit is putting it into mass storage mode. This mode is used to upload and download map data and updates to and from the computer to the unit. If this is happening when it is just connected to a power source and not the computer, it would mean that the power cable being used is not the correct one.
The recommended vehicle power cable for the Oregon or Colorado 300t will need the Garmin part number 010-10851-11 .
Sep 16, 2011 | Garmin n vi 300 GPS Receiver
Everytime i coneect to psn a error keeps comin up 80023121
This one is usually connection to the play station network problems, theres a few people with this today so maybe they are making some changes to the PSN servers it may well go away by itself. if not gone by tomorrow, check all you internet connectivity (ensure that you have a link to the internet on maybe a home computer).
Apr 21, 2011 | Sony PlayStation® 3 (80GB) Console
I'm trying to connect the ecb3500 as an AP Router to get wireless access from my cable modem. THe old LinkSys worked fine, although it has low power, but the ecb is unable to connect (status of connection...
ECB3500 Can I downgrade firmware safely with this product?Yes. I cannot get into the device from my computer. What is the basic setting check?
- Make sure you are directly connected to the unit.
- Do not have a switch or router in between and do not connect wirelessly.
- Make sure your power injector/adapter is on, power is going to the unit, and the "network" side is going to your computer.
- Make sure your computer is set to a static IP address of 192.168.1.10.
- Type in 192.168.1.1 using Internet Explorer.
How to change the IP Address?
The default IP address is 192.168.1.1. This IP address is typically in conflict with many routers out in the market. You will need to change the IP address manually to an IP address that is different but part of the same network. This means if your router IP address is 192.168.1.1, you should change the device to 192.168.1.2, for example. We recommend you change the IP address before other settings. You change your IP address in the "LAN" section in the GUI.
How do I reset the device?
Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
How do I set up AP WDS Repeater?
Click here for instructions.
How do I set up the device under Apple MAC OS X environment?
I cannot connect or maintain a log in to the device.
We recommend using internet explorer with at least IE7 or higher. Make sure you have latest version of Java script.
What distance in kilometers (km) should I set the device to?
Default is 1km. If you are setting up long distance point to point links, the time it takes the radio wave to get there needs to be considered for proper handshaking (ACK response). This window should be accurate within 5 kilometers. In other words if you have a 5 kilometer link, ideally you should set it to 5km, but a setting of 1km to 10km should keep you in an acceptable window. For short distances, keep this to 1km.
What is a point-to-point link setup?One unit would need to be in AP mode while the other in CB mode. The AP should be connected directly to the routers LAN port, and the other will be in Client Bridge Mode linking back to the AP. The Client side will then provide a WIRED connection for users of the remote location. You can choose to connect this wired connection to just one PC, or to a switch, hub, or another wireless access point for multiple users at the remote location. What is a Client Bridge (CB) Mode?
A client connects to an access point. Your laptop is a client. A bridge is something that connects two "wired" networks together. A client bridge therefore is a radio that wirelessly bridges two networks. The Ethernet port of the 2610 in CB mode provides the wired connection to the remote location. This Ethernet port can directly connect to a single PC, a hub, a switch, or another router.
What is considered a "good" signal?The signal meter is not available in AP mode. In CB mode, under connection status, a signal of -74dbm or better is a good signal. It's important to understand which direction numerically is a better signal. Dbm's are referenced to 1 milliwatt. 1mW = 0dbm. A stronger signal would be a positive number and a weak signal would be a very negative number. For example, a -50dbm signal is stronger signal than -92dbm. What is spanning tree protocol?
When there are several possible paths a packet can route to (redundant links for increased reliability for example), a loop can occur (jamming up the network). It is used to prevent these loops.
What is the default gateway?The default gateway is your router's IP address. The default gateway information is not required, but is recommended.What is the default user name and password to log into this device?
Log in name is "admin" and password is "admin" by default.
What is WDS Mode?Stands for Wireless Distribution System. Allows access points to link together and provide repeating. Note however, this repeating comes at a cost of reduced bandwidth. Bandwidth will be reduced by 30-40%, and it is recommended that NO multiple repeating hops be done for this reason. Which antenna connector is the primary antenna?The one closer to the power jack.
Jan 06, 2011 | EnGenius Technologies ECB3500 802.11g High...
Connecting dell mini inspiron with LCD with HDMI cable on both si
You just need a HDMI cable to go from the laptop to the TV. It is refered to as a patch cable. You then go into the TV menu and set it to component or in some cases it will say computer. The VGA on the TV just allows both style interfaces to be connected.
Jun 20, 2010 | Dell Inspiron Mini 10 Notebook
Lack of data transfer when cell phone is connected to router
1.Use the USB dongle to the PC and see if you can transfer your data complete
Apr 27, 2010 | Airlink Router
How to connect net with reliance net connect- huawei ec325
You have to install driver for this reliance netconnect data card which is given below.
Click Here for Downlod
Mar 28, 2010 | Dell Computers & Internet
Our nintendo wii wont connect to the wireless coneection
Is it a secure connection? if so go to
http://www.ehow.com/how_2250396_connect-wii-secure-wireless-network.html
and follow the tut. also make sure the wii is fairly close to the router. I have trouble with mine if I get more than 30 or so feet away from the router with it.
Apr 19, 2008 | Computers & Internet
PC Chips (M925G) Motherboard Logo
32 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
