Question about Sunbeam 3211-2 Electric Kettle
Rust coloured spots on insie of kettle
I am not sure what model I have but it is a 1.7 litre stainless steel Sunbeam jug. The problem is there are all these rust coloured spots at the bottom of the jug and I am not sure if it is still healthy to boil water in the jug any more.
Have you heard of this happening before?
Is it rust?
What should I do?
Myles
    Scholar:
  • 145 Answers
We buy DeBruce Polish at debruce polish.com, this stuff really works.
Posted on Aug 18, 2009
I have faberware stainless steel knife set knives have rust spots. What & why??
How do remove rust spots from stainless steel Yahoo Answers
Yes, stainless will rust. The above link has helpful information on how to treat rust spots on stainless. The web site suggests using a mild acid, such as oxalic acid, which can be purchased at Home Depot or Lowes. Use a green scrub pad, as recommended. Hope this helps....
Apr 28, 2014 | Refrigerators
Filter replacement
Remove limescale with vinegar. A thorough job will clean filter too!
Feb 17, 2014 | Morphy Richards Accents 43836 Jug Kettle,...
The door is getting rusty. I believed that stainless steal didn't rust. Is there a way I can remove the spots?
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to this site.
Mar 22, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Looks like the stainless steel is rusted.how do you fix that.
Stainless steel should not rust, and if it corrodes it does not show the normal red rust colour. Hopefully your surface is not steel plated to represent stainless steel. If it is stainless steel it would be something that has stained it and this can be removed with any quality commercial mild abrasive cleaned and Scotchbrite or a patent soft fine polishing block available at most large hardware od department stores.
Jan 18, 2011 | Kitchen Ranges
Rust on stainless steel
1) Take rust off with Bar Keeper's Friend and a damp sponge.
2) Rinse and dry
3) Wipe with mineral oil.
Will be good as new
Sep 24, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Rust spots on Bosch door panel (1 year old)
I have same problem, low grade stainless will rust, could be the problem
Feb 25, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Kitchen Appliances - Others Logo
1,054 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
