Canon PC-850 E002 Error Code
Hi I have a Canon PC-850 copier that keeps showing an E002 error code. How can I fix this? Thanks for any tips you an impart.
  • Anonymous Mar 30, 2014
    E001 E001E002
  • 41 Answers
After some searching, it appears that this error is common on all Canon Copiers. It means that "Fusing unit not heating up" This is most likely due to a bad fusing unit, or a component the fusing unit. Recommend replacing Fusing Unit.
Posted on Mar 19, 2008
I fixed it by putting it in service mode. (paperclip straightened to act as a pin pushing the reset button behind the front cover and simultaneously holding down lid release spring on the left with a pen). It reset itself and no more error code.
Posted on Jun 04, 2008
SOURCE:
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete · Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
Error code E002
  1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
  2. Press 2 and 8 on the keypad at the same time.
  3. Press the User Mode key on the control panel.
  4. COPIER Icon
  5. Press the Function icon
  6. Press the Clear Icon
  7. Press the Err Icon
  8. Then ok.
  9. Exit
  10. Power off
  11. Wait 1 min.
  12. And Turn on machine
May 14, 2016 | Canon Office Equipment & Supplies
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
May 13, 2010 | Office Equipment & Supplies
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error code: E002 at canon NP6551
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Canon PC-850
A E001 code is a fixing error code. It has to do with the heating lamp or the thermister or the thermal fuse or it could be all 3. Dose the fixing lamp turn ON. If no it is the fixing lamp or thermal fuse. If it turns ON and warms up and then codes out then it is the thermister. It could also be the whole fixing unit is bad.
Mar 26, 2008 | Office Equipment & Supplies
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
Open Questions:
173 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
