Hotpoint WMA58 Front Load Washer Logo
Posted on Apr 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint WMA58 working but will not spin - drum rotates but will not speed up.
Anonymous
Level 3:
  • Hotpoint Master 43,501 Answers
  • Posted on Apr 12, 2010
Anonymous
Hotpoint Master
Level 3:
Answers
43501
Questions
0
Helped
10842847
Points
101584
It sounds like your belt is loose and needs to be replaced..
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
1helpful
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
4helpful
Excessively noisy when it spins. The faster the spin the noisier it gets.
Sounds like the Drum Bearings are gone they are **** on Hotpoint..Could be quite expensive depending on age...3 years old you will need a half drum complete with Bearings approx cost £80 plus labour....if more than 4 yrs old then perhaps bearing kit plus 3 hrs labour....Hotpoint give a FREE 5 yrs parts warranty however CALL CHARGE....£105 approx parts are free.....You need to ecide if you should fix or just buy a new one........
When on spin,the drum is rattling and making a lot of noise
More than likely the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough, or is rumbling or grating, then the bearings have failed.
2answers
Loud crunching noise when spinning really noisey
The bearings of the basket, are damage, maybe due to water leaking and getting rusted, or maybe the shocks are also wearing off. expensive fix on the drum basket.
3helpful
My 13 year old wma58 makes a lot of noise on spin rinse
To be certain if it is the main bearings, remove the lower rear panel of washer, remove belt, and spin drum from the front.
If it feels rough or is rumbling, then the bearings have failed..
If no noise from drum then it could be noisy motor bearings.
At that age, it certainly would not be cost effective either way.
Hope this helps.
1helpful
My machine is making a noise as is it is spinning noise but drum will not spin around. any suggestions
Check to see if you can turn drum by hand, if you can, then prob could be belt, or motor not turning under load, check brushes in motor.
Please rate my solution.
thanks.
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Hotpoint WMA58 Washer won't do proper final spin
I ve come across this problem many a time... my job is recondtioning these models of machines for the last 3 years..
This problem has three solutions..
the first one is the control board,, very unlikey but has been known,
secondly the wiring loom unlikey but has happend.
Thridly the motor itself ....This is the most common remedy to this problem.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
