My memory stick quit!
Windows isn't recoginzing my SimpleTech 2GB USB 2.0 Bonsai Xpress Flash Drive it says unformated but won't format. Tried formating with XP and with win2000 but get the same message unable to format each time.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ahh...well..did you go get fresh drivers for that little beastie?
    Sergeant:
    Champion:
  • 277 Answers
Try using startup disk of windows xp,, its very sensitive..be carefull... .. then be sure that your usb is connect to the computer.....del the partition of usb device.... then create partition, last format it... be carefull that you want to format is your usb device not your hard drive.
goodluck..
Posted on Mar 19, 2008
How do i reformat a data traveler kingston 2 gb usb flash drive? i tried formatting but it shows that it is Chipsbank usb flash drive with only 8 mb memory and then it wont complete formatting when i...
Are you positive there isn't a flash drive stuck in a USB port somewhere else on the computer? Very peculiar for the computer to be recognizing a completely different device.
May 18, 2011 | Electronics - Others
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I tried deleting everything from my memory stick becaues there is not enough space for my file, but after deleting it, I still dont have enough space, it keeps saying the avaliable space is 270MB even tho...
Try to format the drive from your computer, instead of just erasing it. Also, memory cards do go bad too.....some times quite easily.
The good news is they are VERY inexpensive now of days if you do need to replace it.
Dec 22, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I deleted Photos from my 2G Memory Stick Duo on my computer, now the camera says there are no images but has only 100mb memory space available
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format Memory Stick Duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 25, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
2gb memory stick became 8mb and it says disk is not formatted. when i format it, it says windows cannot format this
Windows cannot format USB memory sticks, you need the HP USB memory format tool . Get it here.
http://en.kioskea.net/telecharger/telecharger-127-hp-usb-disk-storage-format-tool
Dec 16, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
Jun 02, 2009 | Electronics - Others
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
