Question about Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7200M 800 Watts Mono Amplifier
I was wondering what size power wire is recommended to power my Pioneer GM-7200M 800 Watts Mono Amplifier. I have this amp powering 2 12" MTX 4500 Thunders. I had a smaller wire connected to it and it would kick in and out and then eventually just stop. So i connected a wire that was a little bit bigger and it did the same thing. I was a little concerned that something could be wrong with the amp. but then again i wasnt sure if i just needed a bigger wire.
    Problem Solver:
  • 8 Answers
You Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
Posted on Jun 10, 2009
Turn the gains down, it is turning off so that it does not malfunction. It is in the users manual. Hopefully this works if not sorry dude
Posted on Aug 05, 2008
I have this amp and i use 4 gauge power and 4 gauge ground
Posted on Apr 12, 2008
    Sergeant:
  • 300 Answers
The 800W rating is peak, which, unfortunately, means very little. But the RMS rating is 360W. My amp is considered a 500W amp and they recommend 6-8AWG wire for power and ground. For yours, I would say 8AWG should be about right (although larger wire is always welcome).
Posted on Mar 19, 2008
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
New amp
Something is def. wrong. did you check the fuses on the amp after the light went out? probly have a bad connection somewhere. check ground wire and power make sure they have a good connection and arent cut up and shorting out.
Oct 21, 2009 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Pioneer GM-7200M 800 Watt Amp shut off and wont turn back on.....
Hiya, first check by triggering or powering the amp manually by putting a voltage at the trigger. Just use a jumper from power. If the amp comes on then check the feed from head unit. Loose wire, inline fuse near the head etc.
If it still doesn't come on the hate to say its gonna have to go in for repair. Could be anything inside from protection, blown track etc.
Hope that helps
Jul 27, 2009 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7200M power problem
Check your GROUND wire might be touching something and making bad contact.
Jun 09, 2009 | Pioneer GM-7200M Car Audio Amplifier
Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Jun 05, 2009 | Pioneer GM-7200M Car Audio Amplifier
Can't get my pioneer amp to power on
This happened to me make shure that you check fuse underhood/ and the fuse inside of the amp.
Jan 11, 2009 | Pioneer GM-7200M Car Audio Amplifier
My 600 watt amp for my car just now start putting a red light on
You may need a new power supply inside amp. If you where running speakers with to many watts it will burn up the power supply. Try unplugging all wires. Replug them in also check fuse underhood and inside amp
Dec 12, 2008 | Pioneer GM-7200M Car Audio Amplifier
Is it good
If you are using a GM-7200 amp, it should sound great. Both the amp and the subs are rated at 800 watts so be careful not to overload the bass by turning them on full power. It is good practice to have a slightly lower watt amp than the subwoofers. If you can power your rear speakers from the amp, that would take away some power to prevent the subs from overloading. Overall, you should get a nice THUMP!!
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7200M Car Audio Amplifier Logo
736 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
