Question about Panasonic DMR-EZ47V DVD Recorder/VCR
DMR--EZ48V I need your help to get my remote control to operate my DVD recorder/VCR combo. I was in the setup menu and accidentially set the remote control to "RC2" and now the remote isn't working at all. Do you have any suggestions? Would greatly appreciate some.
  • 3 more comments
  • willow70815 Mar 20, 2008
    I called Panasonic and spoke with a Tech and he instructed me to point the remote at the unit and hold the "OK" button and the number "2" for 10 seconds. It worked perfectly.
    The solution that worked for me is to point, press, and hold buttons "OK & the number 2" for ten seconds at the unit. Then press the power button to see if it operates the unit.
  • Peggy Cutler Jan 25, 2009
    I have Panasonic DMR--EZ48V, I set the remote control to "RC2" then I changed my mind and want to go back to RC1, but the remote and the unit are not working at all. Whenever I push any button on both devices, it will always show RC2 and flashing… I even unplugged the vcr/dvd for a few seconds then plugged back into the wall, still same problem above.
  • Anonymous Mar 17, 2014
    want to play camcorder through VCR..DMR-EZ48V
  • Cinlarr
    Cinlarr May 10, 2014
    thank you - we had this same problems and no where in the manual does it say "if all else fails do this"
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Posted on Jan 28, 2009
  • red800702 Feb 06, 2011
    This worked. For me, I was receiving error message RC 1. I had to press and hold the "OK" button and button "1" at teh same time for ten seconds.
    If you get error message RC 2--press and hold buttons "2" and "ok" for 10 seconds
    If you get RC 3--press and hold buttons "3" and "ok"
    Thank you again. This saved me $38
  • Cinlarr
    thank you - thank you!!!
Thanks. That worked great
Posted on Jul 29, 2012
  • james
    james Sep 09, 2014
    does not work from my rca remote.
Can't get into the setup on Panasonic dmr ez48v remote says rc2 I tried to switch to rc2 on the remote it does nothing
See if you can access the factory reset on the VCR, that should send everything back to normal.
Oct 23, 2016 | Panasonic DMR-EZ48V DVD Recorder
On A dmr.ez48v on schedule a program on the speed on how mu ch time is left at the top of screen how do you change the speed
On the remote at the bottom next to record is RECMODE this changes the speed. You will have to select each recording you want to alter to change it I think.
Oct 20, 2014 | Panasonic DMR-EZ48 Dvd/Vcr Combo Recorder...
Operating a panasonic dmr-ez47v without a remote control
Many DVD recorders need the remote for a few functions like menu and setup. The remote part # is EUR7659T80 in the US. You can order parts here . it costs about $35 US. Save yourself some headaches.
Feb 21, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
Remote broke how can i record vcr/dvd player . wnat to record on my vcr?
I assume this combo unit has basic front panel buttons (behind the right-hand door - where the copy button is) - there should be a drive select (VHS or DVD) button stop play record. I strongly advise if you really need a remote for this model, particularly when it comes to menu/setup options, that you search various online and similar stores for one.
The cost will depend where you go and who you deal with - and if the remote is available (you can always ask Panasonic about a remote for a DMR-EZ48V even though your model may be a DMR-EZ47V - they both use the same remote (N20AYB000136 or equivalent number); they can probably tell you how to order one through them, the price, etc.
A universal remote may work, but with limited functions. If the combo unit works in general, you should not have too much trouble obtaining a replacement remote (just keep in mind the model above).
The remote may cost just over $100 but remember, this is only if you want full control of your combo unit.
Mar 13, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
2,825 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
