Excel Macro to find out non-keyboard ascii characters
I need a macro code to find out all the non-keyboard characters( symbols, greek letters,etc) not found in keyboard
  • ddavis4 May 13, 2009
    I have single quotes in a data file that my database cannot handle and needs to be removed before loading. There are also other characters as well that I need to detect - Kanji, etc.
    Scholar:
  • 101 Answers
Not a macro but if you need a particular code for a symbol. Try Start button and then run
type charmap
You will find all the symbols here and in the bottom right hand corner it shows the keystrokes for selected symbol.
Posted on Mar 20, 2008
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
I want to know about macros
you can find more information about macro and usage of macro from
Automate computer tasks easily with macro software
Oct 29, 2010 | Computers & Internet
How to type n with this symbol(~) on top of it...????
You can use ascii code which consists on using the alt key on your keyboard and a combination of numbers, for the ñ you need to use:
ALT+164
that works everywhere, word, chats, websites, email, etc. Here is a link where you can learn more about ascii codes:
http://www.asciitable.com/
I hope this helps you and don't forget to rate or leave a testimonial. Thanks for using Fixya!
Mar 13, 2010 | 01 Communique I'm InTouch 3.4 (28-027128)...
How to make degree sign in computer using numbers?
A better way to enter special symbols in Windows applications (such as Word), is to take advantage of the symbols in the fonts provided by Windows. For example, in Word, use the following steps:
  1. Click on "Insert" (in the menu at the top of the page)
  2. From the drop-down menu, select "Symbol". A chart of special symbols will appear
  3. From the chart, you can select a symbol to insert into your document by highlighting the symbol, and clicking on the word "Insert" at the bottom of the chart.
How do I generate extended ASCII characters from the keyboard?
A: DOS will allow you to enter extended ASCII characters into many programs. Here's how you do it:
  1. Make sure NumLock is enabled on your keyboard.
  2. Press and hold the ALT key.
  3. While holding down the ALT key, enter the 3-digit decimal code for the extended ASCII character you want to generate.
  4. Release the ALT key.
Feb 18, 2010 | Broderbund Learn MS Windows XP and Excel...
How to shoot macro and close up images
To activate macro mode on s5000 you need to press the 4-way controller on the back of the camera to the left (it's labelled with a "flower" symbol).
Make sure you turn macro mode off once you've finished with it as it will cause autofocus to slow down with non-macro focusing.
Good luck,
Raf
Nov 13, 2009 | Fuji FinePix S5000 Digital Camera
Macros
After you record your macro do the following.
Open the excel file contains the macro. Go to tools and go to macro and click on macros. Select the macro you wish to add the close operation. Click on Step into... This will open up the visual basic editor. In the code window, at the bottom row you will see End Sub. Right before that row, type workbooks.close
Save the macro by clicking the save button. And you can run your macro to see if it works. I tried, it does :) Good Luck :)
Aug 18, 2008 | Microsoft Excel for PC
Macro
Hi motilal
Follow these steps to create multiple macros
Click the Microsoft Office Button , and then click Excel Options.
In the Popular category, under Top options for working with Excel, select the Show Developer tab in the Ribbon check box, and then click OK.
Note The Ribbon is a component of the Microsoft Office Fluent user interface.
To set the security level temporarily to enable all macros, do the following: On the Developer tab, in the Code group, click Macro Security.
In the Macros Settings category, under Macro Settings, click Enable all macros (not recommended, potentially dangerous code can run), and then click OK.
Note To help prevent potentially dangerous code from running, we recommend that you return to any of the settings that disable all macros after you finish working with macros.
Open the workbook that contains the module that you want to copy and the workbook that you want to copy the module to.
On the Developer tab, in the Code group, click Visual Basic.
On the View menu, click Project Explorer .
Drag the module that you want to copy to the destination workbook.
Regards,
TheAssembler
May 06, 2008 | Microsoft Excel for PC
Character Encoding After Sync.
HI, U DO'NOT USE THE GREEK CHARACTERS IN UR PC SUITE. REINSTALL THE PC SUITE WITH GREEK LANGUE VERSION.
Mar 02, 2008 | Nokia 6288 Cellular Phone
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Macro to be used in Excel
Instead of me teaching u. i would suggest u learn it by following the simple steps.
1. Click Tools > Macros > record
2. do some common operation like copying data, creating graphs, etc.
3. press alt+F11 to go to vb editor, to see ur macro recorded
4. study it ... u will learn easily
or
try the book 'Microsoft Excel Visual Basic Macros Examples' at http://www.add-ins.com/vbexamplestopics.htm
bye
have a nice day
Jan 26, 2008 | Computers & Internet
Computers & Internet Logo
1,962 people viewed this question
Alun Cox
David Payne
David Payne
