Question about IBM ThinkPad T22 2647 Notebook
Problem Keyboard Keypad J,K,L,U,I,O,M, is have a number 1,2,3,4,5,6,0 so when i press the Keypad J the laptop writte 1 and K writte 2 so how can i resolve my keyboard
  • Anonymous Mar 20, 2008
    After re-boot Keyboard letters (J,K,L,U,I,O,M) always revert to Numberical
    rather than the alphabetical. I know to SHIFT-Numlk to switch back and forth, but how to set config. to default to alphabetical ?
  • dorian-2008 Apr 07, 2008
    when i press j at keypad is writing 1,when i press k is writing 2.how many ways i have to resolve this problem?
  • 47 Answers
If that doesn'twork, press fn+Num Lk
should work
Posted on Apr 08, 2008
  • geek comp
    geek comp Apr 10, 2008
    guest,
    shut down computer, then start it again (don't just press "restart") then, press F1 to go to the boot menu. you should find an option for numlock on startup. configureit to off. save and exit boot menu. then restart!
    hope this helps
    Guru:
  • 377 Answers
Hi dear
press Fn+Shift
try that ok
cropp
Posted on Mar 19, 2008
How do I unlock the number key on my E6500 latitude keyboard
Hi Tiffany,
Found this after googling .....
Here is how you enable the number lock feature:
1) While booting up press F2 repeatedly
2) After the Dell logo appears, you will be diverted to a Settings menu
3) Expand "POST behavior"
4) Select "Keypad (Embedded)"
5) Press the "By Num Lock" button
6)Press "Apply"
7)Press "Exit"
Nov 18, 2014 | Dell Latitude E6500 Laptop
Numeric keypad
1.Hold Fn (bottom left corner key on your keyboard beside "Ctrl") and press F11 key once (or find symbol that looks like "lock with number 1 inside" )
OR
2. Find key on your keyboard called "NumLock" and press once.
Mar 17, 2014 | Dell Inspiron Computers & Internet
Numerical keypad offset numlock on keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 18, 2012 | Genius KB9229047 Keyboard
Sony Vaio Laptop only typing numbers 1234567890
see on your kebord Fn, + num pad, then will type all corect
May 28, 2011 | Computers & Internet
I have problem with Acer aspire keyboard, some keys are not working
You may accidentally have turned NumLk on which causes the keys on the right part of the keyboard to act as a keypad for entering numbers. A little padlock with the number 1 in its middle is the indicator for NumLk and it will be lit or a LED bar underneath it will be lit when NumLk is on. On the Acer Aspire One 8.9" screen model ZG5, the NumLk is toggled on/off by holding down Fn and pressing the F11 key. Also, when NumLk is on, pressing U I O gets 4 5 6 and J K L M gets 1 2 3 0. The reason for embedding the numeric keypad within the usual character keys eliminates having a separate set of keys for the keypad function resulting in a more compact keyboard that better fits with notebook computers such as the netbooks which have smaller screen sizes.
Apr 25, 2011 | Acer Computers & Internet
I cannot writte some letters
Obtain any model of USB keyboard from any other computer and plug it into your MacBook. If you can type those letters from that keyboard, you have a keyboard hardware issue. If you still can't, check System Preferences / International and make sure you are set to use the US keyboard.
Sep 08, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Long beep at starting and stuck ''\'' key
its akeyboard fault basically.it may be of keyboard controller inside the motherboard, but 90% it happen due to keyboard failure. remove the internal keyboard and attach a external keyboard and see is there same problem. i think after doing so u can find out the proper faulty things.
Aug 23, 2009 | Acer Aspire One D150-1587 Netbook
Keyboard problems
You have accidently switch on the Number Lock and turned these keys into a number keypad.
On some model laptops the NumLk can be toggled on and off by holding the Fn key and pressing one of the function that has a keypad symbol or labeled NumLk.
On other laptops such as ThinkPad it is the Shift key + the NumLk/ScsLk key.
May 06, 2009 | Computers & Internet
Ican"t type numbers can you please help
From Dell user manual:
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
ACER 5620 Extensa keyboard problem.
Hi, your Laptop has a integrated keypad. You or someone else might of turned this on, thankfully it is easily fixed. Just follow these steps,
1. Find and press the "Fn" key.
2. Find the F11 key there should be in blue letters "NumLk"
3. Press F11 while holding down the Fn key.
This should turn off the integrated keypad
Hope this works ~Kaleb~
Nov 12, 2008 | Computers & Internet
IBM ThinkPad T22 2647 Notebook Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
