Question about Avaya 4610
Converting 4610SW H.323 to sip problem
I have done all setting whatever required in for this conversion.
But when i reboot phone its just showing "Registering" on top line display of phone.
its showing sip phone feature, but i m not able to make call from tht.
please let me know wher is th problem exactly?
Did you figure it out?
Posted on Jun 24, 2008
SOURCE:
Password for avaya 4610sw
Talk to your system administrator. The password is set by them and can be anything....
Apr 17, 2010 | Avaya 4610SW IP Phone
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Jan 21, 2010 | Cisco 7912G IP Phone
The Avaya 4610sw phone will not find the main phone system an Avaya G350 it has been unplugged from the system and when it was plugged back in it would not find the router or system
It's probably a problem with your DHCP settings, if you try manually setting the IP configuration on the phone it should find the server/control unit, haven't used 46x series myself, but if you reboot the phone at some point it should give an option to configure manually, if you have another working phone you could get the IP configuration off that one, think you can find them somewhere in the option panel on a working phone.
Apr 22, 2009 | Avaya 4610SW IP Phone
Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Jan 13, 2009 | Avaya 4610SW
Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Dec 16, 2008 | Polycom SoundPoint 330 IP Phone
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
May 18, 2008 | Cisco 7910 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Avaya 4610 Logo
411 people viewed this question
Top Avaya Computers & Internet Experts
Thomas F. Schneider
Vincent G
Vincent G
Duncan Mutch
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
