Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Service manual dealer
Hi floyd11. It looks like my PT-53WX53 also has a convergence amp problem. Where did you order the service manual? Thanks for your time.
  • doug56 Mar 27, 2008
    Thanks Floyd11. I had the week off so I purchased one from servicemanuals.net. The resistors arrived in a day (digi-key) but am still waiting for the convergence ICs (www.electronic-repair-kits.com).
Purchased from paradise manuals, I can try to email it to you if you still need. my email address is fpeltier@aol.com
Posted on Mar 25, 2008
I have a Panasonic PT-53WX53 RPTV. Recently, the very top and very bottom are cut off. Using the Aspect button on the remote accomplishes nothing except when putting it in 4:3 mode. I can get into the...
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How do I remove the top part of a PT-53WX53 panasonic rear projection tv. I can get the back off but not the top part off. My Mini-van isn't big enough, so i need to split it into two parts to transport...
Hello Griff,<br />Did you ever get a copy of the Service Manual from Lonemountain? If you did, would you send it to: vipnite at yahoo dot com<br />.I would greatly appreciate your help. I hope you were able to take care of your problem. Was yours a convergence problem as well?<br />Kind Regards,<br />Ricky<br /> <!-- from fixya rte -->
Nov 11, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Service Manual for Panasonic PT53WX52F
<span class="postedby"><span style="font-weight: bold;"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblAuthor" lang="6649">lonemountain,<br /><br />Did you receive the Service Manual? I'm in a similar position with convergence problems. If you did, would you send a copy to<br />vipnite at yahoo dot com<br /><br />I would greatly appreciate your help.<br />Kind Regards,<br />Ricky<br /></span></span><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblTime"> </span></span> <!-- from fixya rte -->
Dec 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
PT-44LCX65 Convergence
Look in the service manual for the section on using the adjustment set-screws. (I'm not an expert, but this sounds like what you are looking for.) This section is somewhat toward the back of the manual before the electrical schematics and part explosion pages.
Jun 03, 2008 | Panasonic PT-44LCX65 Television
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
How to do convergence on a PT-53WX53
Hello Yann,
Please be advised that doing the convergence in service mode is a very complicated process. This could mess up your TV even more. The best TV tech out there finds doing convergence a Headache. Doing convergence is part of the repair that most TV tech fears. Email me if you still want it. I will not post here for the general public.
Best regards
Mervin Guy
Oct 15, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Power comes on then goes back off.
More than likely, the two convergence IC's have to be replaced.
Jan 28, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
