Question about Dual XDVD8181 Car Video Player
Cd player won't read cds
When i try to load a cd in the cd player it just spits it back out it doesn't even go all the way in. when i reset it and try again the same thing happens! please help me before i either throw it off the fifth floor or try to take it apart and mess everything up all together!!!!!!!!!!!!!
  • Anonymous May 10, 2008
    when i try to load a cd in the cd player it just spits it back out it doesn't even go all the way in. when i reset it and try again the same thing happens!i need help with that...
  • Anonymous May 15, 2008
    mine also takes the cd in only half way and then spits it back out. it wont load them all the way. wha do i do?
Cd Lens cleaner
Posted on May 12, 2008
Mine too!IT WAS PLAYING SEINFELD FINE,WENT TO CHANGE DISC,AND NOW,NOTHING!
Posted on May 14, 2008
Mines fucked up to, i need answers
Posted on May 02, 2008
Put your pc into system recovery and it will do a driver rollback.
Job done!
Posted on May 21, 2009
I'm with you, mine's ready to take flight too.
Posted on Apr 08, 2008
  • Sarah Keeley Apr 08, 2008
    great site, I hope it helps me and you.
    http://www.kuro5hin.org/story/2004/3/24/...
Cd player wont load
It is hard to fix factory radios. Most times the only way to fix it is to buy a new one.
May 25, 2014 | Rockford Fosgate Car Audio & Video
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
I have a 2001 Honda Crv, the cd player keeps ejecting CDs before it has the chance to load them. The radio works fine, and I gave tried burnt and original disc CDs. Can anyone suggest a solution?
Are these CDs that you burned yourself? Older CD players won't recognize the audio file format of this kind of recording, only the established file format that typical retail CDs have used for years. In recent years, CD players have been developed to recognize more file types than just the old format; but with an older player like you have in your car, it wouldn't recognize what you were trying to play, as if you put a DVD in. It balks, and spits it out. You can burn CDs with the correct file format, you just need the appropriate software or file translator.
Apr 14, 2012 | Car Audio & Video
My cd player was working fine with my cds, then it began to spit them back out reading err, I put another unit in, specifically a 98 blazer cd unit and even that unit read err with my cds, any suggestions?
CD's could need to be cleaned.
If you burned them yourself, the CD's could be
scratched are dammaged.
Unlike store bought CD's home made CD's do not have a
protective plastic coating.
Jul 11, 2011 | 1997 Chevrolet Blazer
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Cd player took all six of my cds now they don't
If you know how to remove the radio then open the unit and remove one by one. Make sure you are ejecting cd's properly.
Oct 23, 2009 | Car Audio & Video
2006 lincoln zephyr cd player won't play cds
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 27, 2009 | 2006 Lincoln Zephyr
CD Player won't read disc's. ERROR message
Well if the unit came with car over 10 years old, u can't clean it might have to just replace. buying a new one will cost as much as trying to fix that one.
Apr 10, 2009 | 2003 Dodge Grand Caravan AWD
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Dual XDVD8181 Car Video Player Logo
1,121 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
