Question about Mitsubishi WT-46809 46" Rear Projection Television
Convergence issue - bowing rainbows on sides.
3/19/08
I'm having the same problem as a few others with the center in good focus and the edges gradually blurring with colors bowing out of sync. This has been happening for almost a year and I have assumed the problem is a cold solder joint or loose connection. When it first happened, a light tap on the top of the set straightened everything out for as long as the set was on. Eventually the tap wasn't enough and it would happen every few minutes. I have an electronics background and decided to remove the back and check all connectors for a loose fit. I replaced the back and the set worked fine for a few weeks, then started acting up again. This time I removed the back and with the power on and rubber gloves on, I wiggled each connector I could reach until the picture returned to normal. The circuit board with the large heat sink in the middle of the set seems to be the culprit and looks difficult to remove and check solder joints, so, for the last six months I've just been turning the set on and giving the heat sink a wiggle with the glove on and the set behaves for the day (NOT recommended for someone with no experience or respect for electricity!). If anybody has determined what might be loose and on which board I should look I would appreciate the heads up. Just because the problem goes away when I wiggle the big heat sink doesn't mean that that board is at fault. Other components near by also move a little since the heat sink is so long and It's board is large and flexible. I've read other solutions that suggest removing and replacing an IC, but If the problem goes away with a wiggle, it seems I may have a related but different problem. The set is at least 4 years old, but when it's working after my "quick fix" which is getting old, the picture is as sharp and colorful as new.
Thanks for any input you may have.
Woody
dtw@maine.rr.com
  • Speakerman Apr 06, 2008
    Thanks for the solution suggestion, Rob. It turns out that the convergence chips were the problem, but not the chips themselves. I found that 21 out of 36 total solder joints on the chip's pins were cracked and loose or cold soldered when inspected with a 10 power loupe. I was surprised since all the pins have an omega shaped spring bend between the chip base and the circuit board which should have prevented the above condition. I guess the bend should have been larger or of a smaller gage or both.
    The board removal wasn't that difficult. The whole assembly of circuit boards pulls out like a drawer after removing a few screws, wire keepers, several connectors, and high voltage leads. I found a very good pictured tutorial on the process on ecoustics.com. In addition, it would be helpful to take digital photos of connector locations before removal so nothing is missed on reassembly (a sanity check). I found that most of the connections only fit one location by shape or length except the high voltage leads. I marked them with tape before removing. It's also a very good idea to vacuum the assembly brushing carefully with a long bristle soft 1" or so paint brush while holding the nozzle near to collect the dust. This helps prevent dust from getting on connectors and preventing a good re-connection as well as allowing the operating heat to escape more freely. The typical round brush attachment is too big and course to safely and effectively do the job.
    Once the board was out, cleaned, and inspected, I re-soldered all the pins and a few other suspicious joints with .022" silver bearing solder and a small iron, and reassembled the set. It now works and looks as good as new, very bright and sharp. A well spent afternoon!
    Woody
    Problem Solver:
  • 11 Answers
I just fixed my convergence problem on a Zenith 60" rear projection.
I replaced the IC's and removed the convergence board to do so.
Those IC's have up to 18 connections for each one so you may have some loose connection points if we are talking about the same board. The IC's are connected to the largest heatsink for my TV, if you look from all angles, one view should get you a view of the 2-3 IC's present. Most people will tell you to completely remove the convergence board and check all the big resistors on board as well. Fuses are always a good option too. If you can solder well I would unsolder and resolder the IC's at the very least, but it is only a suggestion on my part. I am not a TV technician but an ATM/Computer tech. The boards look like only a sign from God will get them out but can be relatively easy.
Let me know...
Posted on Mar 19, 2008
Color is off with double image?
Is the image bow-tie shaped, with red, green or blue fringing effects? If so, one of your convergence amplifiers has gone bad. (Bow-tie: at least one of the three primary colors in the picture goes out to the corners, but the top, bottom and sides are bowed in at the center.)
If it is simple color fringing, with no color grossly misplaced, something has messed up the convergence. This may be caused by a strong magnet near the set (for example, a poorly shielded audio speaker), moving the set so its orientation in the geomagnetic field is altered or its components mechanically shifted (rough handling).
If a convergence amplifier is bad, replace it before doing anything else. If you just have minor fringing, see your owner's manual for instructions on using the remote control to adjust convergence. If it isn't in the owner's manual, you'll need the service manual. Caution: if you try to adjust convergence with a failed convergence amplifier, not only will it not help, but you will have a lot of extra work trying to get it back to normal after you replace the amplifier. Try a small adjustment along one edge of the picture. If one or more of the selected color dots in the convergence pattern won't move, and you are sure you are following adjustment directions, stop immediately and proceed with hardware repair.
Convergence amplifiers are usually marked STK392-nnn where nnn is a specific variant number. Two are used; I usually change both because quite a few people have changed one and had the other die not long afterwards. Sometimes there is a fuse in the power feed to these modules that is also blown. If you change the fuse without replacing the amplifiers, you'll probably waste a new fuse.
Oct 06, 2010 | Panasonic PT-53WX53 53" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Bowed picture with color divergence
Hi, The Mitsubishi TV set you have uses two of the STK 392-570 convergence correction IC's. These IC's can be purchased from here http://www.mcminone.com/search.asp?keyword=stk392-570&btnSubmit.x=6&btnSubmit.y=7 These are the original Sanyo replacement type IC's. No aftermarket cheapo ones. Unfortunately this board that the IC's come on is part of the main Printed circuit boards. If one was available for a replacement, it would cost in the range of about 400 bucks. The way it sound that your TV set is intermittent, is that the IC's are not bad, but need to be simply re soldered. This happens a lot with this model number or set of convergence IC's. To tell you the truth, I have had to replace these types of convergence IC's very rarely. Mostly when the set come on with bad convergence and does not change. Find a friend or a neighbor who can solder, find the black STK392-570 IC's standing up against a large metal plate, turn over the printed circuit board and resolder all of the pins, just double check all of the solder points for solder bridges. Good Luck
Aug 02, 2007 | Mitsubishi WS-55819 55" Rear Projection...
My problem is that the picture in the screen is out of focus.
I´m changed the canon to TV projection the green and is go out the convergencia above and
side right I don´t know how iter in the menu inter could you tell me how it these. thank you..
Feb 05, 2009 | RCA HD52W59 HDTV Projection Television
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Yellowing screen off-center - not a convergence issue
You might want to try the optic lens adjustment screw on the side of each crt. Mark them before moving.
May 30, 2007 | Philips Magnavox 51MP392H Rear Projection...
Convergence
Im trying to install that same board on the same tv how did you do it?
Apr 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Horizontal hour glass picture
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Dec 16, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Convergance/bowing
most like tes thats all your going to have to replace + the silicon as if you dont thet wil not last as long as they should. Also you may have blow fuseable resistors next to the ICs make sure you check them as well.
Aug 16, 2006 | Philips 9P6044C 60" Rear Projection...
3d/rainbow affect
Sorry to tell ya Gemini, but there are no user serviceable parts inside a TV set unless your a technician as theres several safety issues of Hi Voltage involved as well as unsoldering and soldering. You Have a convergence problem or Pincussion issue with your set. No quick fix for this one. You need to call in a pro to assist you with this repair. Good Luck
Jul 15, 2006 | Samsung PCL6215R 62" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
