Cd/dvd driver has been uninstalled
I can no longer access my cd/dvd player on my laptop. how do i reinstall it?
  • maryg613 Mar 19, 2008
    I've done that it says that reinstallation failed. I'm not sure what else to try. I just bought this laptop Jan 31, 208. I'm having a hard time getting a response from the company. Is there a way to manually find a driver online to reinstall it?
  • 667 Answers
Go to your device manager. Click on the + next to cd/dvd rom drives. Right click on your cd/dvd and click on uninstall. Reboot and Windows will say new device found and install what it needs. This should fix your oroblem.
Posted on Mar 19, 2008
Hai....blh tlng cari drive hp compaq desktop dc5100
hantar emali kat [email protected]
SOURCE:
The CD/DVD/Disc player on my Compaq Presario CQ70 is no longer working
go into device manager and find the cd/dvd device on your list. uninstall it. then run the check for hardware changes in the menu bar. and it should find it and reinstall it
Feb 11, 2013 | Compaq Presario 700 470024-192 Notebook
Gateway MT3422 DVD not recognized
Try in safe mode. Sometimes there are multiple and hidden in Device Manager.
Aug 26, 2012 | Gateway MT3422 RTL Notebook
My laptop says I don't have a DVD burner but I do. How can I reinstall it?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
The dvd player on my aspire 5520 no longer works.
you might have to physically unplug the leads for this cd-rw/dvd-rom burner then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 25, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My dvd player hl-dt-st rw/dvd gcc4522b do not play dvd but can play cd
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
Dec 28, 2010 | Computers & Internet
I can`t open my burner on my laptop
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 07, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
D drive is my CD writer drive. when I try to access the D drive I get the following message. D:\ is not accessable. The drive is not ready
make sure that the cd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
Nov 19, 2010 | Gateway (5500381) CD-ROM Drive
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
My CD Drive is no longer working it says code 39. I also tried my external DVD drive it says code 39 as well. How do I fix this?
hope this helps
Oct 21, 2010 | Compaq (120192-B21) CD-ROM Drive
My cd/dvd player dont work right
If your cd/dvd player doesnt work right after installing a Epson cx4800 model printer on your computer, specifically with the Vista OS, its due to reported issues with the cx4800 printer drivers conflicting with drivers tied to your cd player..supposedly.
Best advice is to uninstall the cx4800 software/drivers and see if your cd/dvd player works right. once confirmed it does, then try to get the windows os to automatically detect and install the cx4800 printer without using the printer drivers that came with the printer.
If after uninstall the printer drivers and your cd/dvd player still doesnt work properly....need likely to reinstall the cd/dvd drivers ..but that can be another ugly problem as for finding the right ones to reinstall.
Dec 02, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Open Questions:
Computers & Internet Logo
123 people viewed this question
Ekse
Alun Cox
