Question about Uniden PRO510XL 40-Channels Base CB Radio
1987 uniden pro 510 xl
I have just purchased a Uniden Pro510XL manufactured in 1987, in mint condition. Like brand new, barely used.
I want to tweak and peak it. Currently it has a 2W dead key with no modulation. I know it will put out 4W with good modulation but all the mods I have found are only for newer 510's.
I would like a visual, schematic, or component ID, so I can find the 2.7 ohm final resistor so I can replace it with a .47 ohm, and where the heck are L5 and L6, they don't exist on my 1987 model? I did find D14 but I'm afraid to cut it and make an overmodulating radio that can't be understood. I just want to be careful with this old radio so I don't blow it up but at the same time I know these older radios can scream if peaked correctly.
Any help would be appreciated!
Thanks!
ajbledsoe@gmail.com
    Guru:
  • 773 Answers
Wow, from what you are saying, you should not be messing with the insides of the radio. Finals, are not resistors, that are TRANSISTORS, and they do not have resistance values at all.
The final is the little black transistor attached to the heat sink at the back of the radio. You can't just change the final. there are other parts that need to be changed if you want to do a high power mod. Don't even mess with it. you don't need too.
Next, D14 is not the uniden model. thats what you mess with in a cobra. Don't cut d14 in that radio or you will prolly blow it up. The diode you want to cut out is D203. DON'T CUT IT!!, Just un solder one leg of the diode. You won't be over modulated. That will bring you modulation up and your peak watts. it will swing to maybe 15-20 watts peak. That alone with make the radio louder.
You really don't need to raise the dead key. With a lower dead key you have higher swing. Its all about the audio. 2 watts for dead key is fine. Thats what I run.
You cannot do any other peaking with out a meter. If you have a meter you can spread the 2 coils behind the large transformer a tiny bit until you have peak wattage. L201 and L202. but from reading what you said, you should probably leave them alone, you will gain only a watt or 2, and its not worth it if you mess it up.
To be honest with you, all you really need to do is unsolder one leg of D203. Make sure you pull the leg out, and make sure it is not touching anything so it will not short.
Now if you do this, and it splatters, you can always solder it back in, and then turn RT201 all the way to the right, I think. If you turn it all the way to the right, and there is not modulation, you just turn it all the way to the left.
Please don't mess with anything else or you will screw the radio up.
Posted on Oct 03, 2009
  • 1 more comment
  • hazzard_coun Mar 20, 2011
    D14? my pro510 said to cut it for audio, however i dont have D14 in my radio at least i cant find it and yes the older pro510 has the D14 but as for the new ones i cant find it!!
  • Thomas Freeman Mar 03, 2014
    don't sped the coils at the back of the radio as they are for audio clarity . i just turn the VR and that should be good enough to much and your audio could clip .. look at CBTricks.com
    oops never spread the coils !!
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
How do I resoder the plug on a uniden cb mi
You need a schematic diagram to make sure you connect the correct wire onto the correct connection, else you'll stuff up the radio.
If you've never done this before, then don't find a technically minded friend to do it for you.
That's my advice.
Cheers,
Peter
Apr 28, 2012 | Uniden Pro 510 XL
I have a uniden cb pro 510 xl cb radio that the speaker doesn't work. I cannot find where or how the speaker connects into the power board. Is there a wiring diagram for this available?
Hi Anie,
START HERE: join yahoo group specific to your radio Make/Model, they have all the answers, plus you can download manuals and other stuff, i.e,. schematic diagrams for your radio.
I hope this helps.
Cheers,
Peter
Feb 12, 2012 | Uniden Radio Communications
I looking for sxematic diagram uniden pro 510xl
I hope you find the schematic diagram for your radio......
Aug 25, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
What do you clip to turn up the power on a uniden pro 510 xl new style
hi you cannot tweak anymore output power from these radios as ajusting any components will damage the rig ,they come factory set at 4watts tweaking it anymore will after prolonged use damage the finals /pa transistor so leave it well alone if its not broken dont fix it goodluck
Oct 27, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl transmitts slightly off frequency. Is there an adjustment for this?
Yes, you need a frequency counter to get IFfreq back were it needs to be. google cb shops in temple, tx
Aug 07, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL Outup
The Uniden 510 xl is quite possibly the easiest and one of the loudest radios I have ever pumped up .Now here's the problem it's been atleast ten years since I've had the cover off one so I can't tell you which diode # it is you clip for the modulation I know that as your looking at it (speaker side up ) it's about halfway on the right hand side buy the audio transformer.Then you change the resistor buy the final transistor , you go higher until you get where you want it , going higher is going to bring your output wattage down ; I usually tried to get it down around two watts . By doing just these two things and maybe a little adjusting you should be able to deadkey 2 watts and swing to 18 watts with just that cheap stock mic. if you change the final transistor I've seen them swing to 35watts.They are fun cheap radios that when you do this no one beieves that that's all your talking on . Good Luck !
Jan 24, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL 40-Channels Base CB Radio Logo
1,675 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
