Question about Sharp AR-407 Copier
Staple problem Have a AR-FN2 finisher that won't staple. I've reset like manual suggests, suppose to click 3 times, but it only clicks 1 time. Don't know if it's not feeding staples through, There are no staples jammed on paper - no indication of staple even touching paper. How do I proceed to fix problem? Appreciate the help.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Pull about 1 inch of staples out of the cartridge, tear off the 1 inch so new staples are flush with plastic cartridge. Reinstall and make 10 stapled sets. By the time it tries to staple set number 3 or 4 you should start to see the staples working. It could take as many as 8 or 9 sets for the staples to advance far enough. Once it staples you are all set/
Posted on Feb 25, 2009
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
MY KONICA MINOLTA BIZHUB C203 IS HAVING TROUBLES ACCEPTING STAPLES. WE FINALLY FIGURED OUT HOW TO USE THE STAPLE FEATURE, BUT AFTER A FEW MINUTES IT STOPPED STAPLING PAPERS. I'VE SUCCESSFULLY REMOVED...
Yes you did good but you didnt get it in all the way... push harder till it clicks in,,,, unless there is no staples in the cart.... tell me how it went
Sep 04, 2011 | Konica Minolta Bizhub c203 Copier
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
Our copier ran out of staples, where do i put more in
STAPLES WILL GO IN THE FINISHER UNIT.OPEN THE COVER AND REMOVE THE STAPLE UNIT AND PUT NEW STAPLE PINS
Jan 07, 2011 | Sharp AR-M350U Copier
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Can u tell me how to load the staples into my arrow t25 staple gun not used it for a long time
Hello. Here is a link to a free manual for your stapler. http://www.arrowfastener.com/upload/manuals/79055000259_manual.pdf
Look on page 3 for the three steps to load it.
1. Press latch in lower rear of gun to remove pusher rod from machine.
2. Insert strip of staples.
3. Replace pusher rod.
Happy stapling! J.
Jun 22, 2010 | Arrow T25 Staple Gun
Arrow Fastener Co./Electric Staple Gun - ETF50BN
First make sure no staple is jammed between the hammer and the anvil or plunger and you might also try to spay with pb blaster or wd 40 and pull yhe trigger several times very rapidly and see if this will free plunger , does work to free sometimes
Jan 22, 2009 | Arrow T50P ARROW STAPLE GUN
Canon imageRUNNER 7095 copier has the error code E00057a-8003 ..... can you tell me what this means? can we fix it on our end? Let me know as soon as possible because our copier has been down for 3 days....
This Problem occured with a finisher V1/V1L attached to our Canon iR7095.
The staple unit didn'tmove back to it's initial position. After restarting the printer there was a really strange clattering sound coming from the staple unit.
Problem was solved by removing all trapped pages from finisher and copier. Probably you have to restart several times. The system should reset and move the staple unit back to initial position.
Aug 12, 2008 | Office Equipment & Supplies
Staple problem
Are you sure you have the correct sorter, they come with diff. options. the same model comes w/wo staples- w/wo book binding etc.
For example : w staples may be an AOor A1 model
wo maybe an AS or B1 model
Jul 17, 2008 | Sharp AR-407 Copier
Sharp AR-407 Copier Logo
469 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
