Question about Philips 32PFL7332D 32 in. LCD HDTV
Setting ***. i have just a dvd player hooked up to my philips ambilight with hdmi and monster cables but when i put in a dvd it only plays on 480p how do i get it to 1080p or i whichever it is
  • 8,596 Answers
You will have to change the dvd player resolution to 1080i (or change resolution for each individual disc), because:
a) there is no way to change the resolution manually on this television
b) this TV maxes at 1080i, hence negating most of the utility of using an hdmi cable (Of course, hdmi cables are much easier to hook up, less messy than component cables; so all is not lost)
Posted on Mar 19, 2008
SOURCE:
When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
you can only upscale through a good amp.set the dvd player to auto.how old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
Jul 11, 2010 | JVC TH-G30 Theater System
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
Philips DVP 3982, 4 months old, hdmi connected to vizio tv. Suddenly now it plays sound but not picture. If I hook it up with composite cables it works, but of course the picture isn't very good. I tried a...
I have few options for you to get the video back on HDMI:
1. Try out changing the video resolution on HDMI set up (select 480p..1080p).
2. Play NTSC disc (to get the 60Hz out from Player). If your are in US.
3. Select the TV system as AUTO/NTSC to get the 60Hz out only on HDMI.
4. if the Deep Color option is available in HDMI set up menu..set it to OFF.
Let me know if you tried all these and still no output.
Apr 26, 2010 | Philips DVP3982 DVD Player
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
No HDMI output with Panasonic SC-PT950
Change the video out settings from your system
Dec 10, 2008 | Sony DAV-S400 System
Picture stretches
Using the remote, you should see a format button . You can go through the options for the best looking picture using this. or you can go to the settings menu for the TV and change the format to stretch or not.
Good Luck and Thank you for using FixYA
Aug 21, 2008 | Philips DVP5982
Hdmi not all that great!
tell to not worry bout it lol!!!
Jun 28, 2008 | Sony Playstation 3 (PS3) Console
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
How do I change the Format from 480 1080i
Make sure that the DVD player is set to output 1080i. Then, check that you have hooked up the DVD player to the TV via the HDMI cable. If you are using something other than the HDMI cable, they the best you can do is 480p.
Dec 22, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Philips 32PFL7332D 32 in. LCD HDTV Logo
196 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
