I turned on my 67 inch samsung DLP and noticed that their is a gray at the top and bottom of the screen which is not giving me the full screen view
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
