Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Graphing Issue In my y=, the symbols to the left of it are all sideways triangles with bars next to it and it won't let me graph more than one function at a time. Please help!
Are there funny arrows at the left of your Y= screen?
Graphing Issue - ti83oops_c.gif The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
http://oakroadsystems.com/math/ti83oops.htm
Posted on Mar 31, 2008
SOURCE:
In the Y= menu, instead of a line in front of de Y1= there's a triangle with a bar. when i click on the triangle w bar it turns into a triangle, when clicked again into 2 triangles and when clicke
You executed the Transform Application and it is still loaded in memory taking over the graphing duties from the native OS. You must unload it from memory.
Press the APPS key. Scroll and find Transfrm, then press ENTER. In the new screen select 1:Uninstall and press Enter.
Go to your Y= function editor to type in up to 10 functions.
Oct 30, 2012 | Texas Instruments TI-84 Plus Calculator
Why does My Y equals column will has triangles next to it and will not let me select more than one function to graph
you have an app turned on for graphing inequalities. Hit App, I am not sure what it is called, something to do with inequalities. Turn that off and your y= will be fine.
Oct 26, 2011 | Texas Instruments TI-83 Plus Calculator
I am trying to help one of my students with their calculator. When graphing multiple equations on her TI-84 plus calculator only one graph is appearing in the window. There is a symbol to the left of the...
The Transfrm application has been executed previously. It remains in RAM and takes over the graphing duties of the native OS. You must Uninstall Transfrm (that does not mean delete it, just unload it from memory).
To do so,
  1. press the [APPS] button.
  2. Use arrow Up or Down (Up is faster) to reach Transfm.
  3. Select it and press [ENTER].
  4. In the new screen, select the number to the left of the Uninstall option.
  5. Go to draw your graphs. You will be able to draw up to 10 graphs.
Feb 04, 2011 | Texas Instruments TI-84 Plus Calculator
How do I clear things left in the stat plot window?
To clean the slate so to speak, just reset the RAM.
  1. Press [2nd][+] to access the (MEM)ory management function
  2. Press [7:Reset]
  3. Press [1:All Ram]
  4. Press [2:Reset]
  5. Press [CLEAR] to erase the "RAM cleared" Message
Calc
Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
When i press Y= button and graph quadratic equations the graphs are not accurate i realized that the symbols to the left of Y1 Y2 Y3... Are different they are no longer lines greater than less than etc....
In the Y= editor, scroll down to the equation in question. Press left-arrow until the cursor goes over the symbol. Press ENTER repeatedly to cycle through the various graphing options.
Jun 24, 2010 | Texas Instruments TI-84 Plus Silver...
When I type a linear equation into my TI 84-plus graphing calculator under the Y= sign and need to view multiple equations it will only show me one and won't allow me to select more than one at a time. The...
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
You can skip the next paragraph if you want
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
Press the [Apps] key. Scroll down or up to reach the Transfm application. Select it and press [ENTER]. If that application was running you will see a new screen that tells you
Transfrm App
  1. Uninstall
  2. Continue
Press1:Uninstall.
Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. To uninstall it, do as for the Transfm and select the option that will unload it from memory.
Jan 14, 2010 | Texas Instruments TI-84 Plus Calculator
We are graphing more than one line at a time. One
To return your calculator's graphing equation to "Y=", press "MODE" from the home screen, then ensure that the option on the fourth row is set to "Func". Next, to show a hidden graph, access the Y= list, then press the left arrow key until the cursor is over the "=". Press "ENTER" to toggle visibility of that line.
Nov 13, 2009 | Texas Instruments TI-84 Plus Calculator
Graphing issue
Damn dude i had the same problem, after a while searching for something that can put this problem away i've finnaly found the way \o/! Try APPS->TRANSFRM-> UNNINSTALL! Hope u can make it!
cheers
Feb 04, 2008 | Texas Instruments TI-84 Plus Calculator
Graphing Problem -URGENT-
The problem is causedby an application called "Inequalz".
To solve the problem, go to the Apps menu and select Inequalz,
then select "quit Inequalz".
This should solve the problem.
Gr. Marijn
Nov 10, 2007 | Texas Instruments TI-84 Plus Calculator
Graphing multiple equations
The symbol on the left of the Ysub1,2,etc. determines what type of graph it is. move the cursor to the left of Ysub1,2,etc. and hit enter
Sep 18, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
243 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
