Nec 1550v multisync
Screen will go black overnight & takes several minutes to come on the next morning when trying to sign on. Problem will get worse... take longer & longer to come on, then will not come on at all. I am a tech & see this on many units. We just discard them when they do this. Any fix? Thanks, Keith
  • 13,433 Answers
The problem is most likely in the inverter or in the powersupply. The lcd matrix is most likely in a fine shape.
Fixing them might not be worth the effort and time.
Basicly Id test it first by replaceing the controlboard / inverter.
after that the powersupply.
Pretty easy fix but is it worth the parts?
In most cases you could replace the
capacitors, xformers digital control devices ad IB4G said
but its easyer to just replace the whole board.
If you need more asistance, let me know. Good luck.
Posted on Apr 02, 2008
    Guru:
  • 1,894 Answers
This is sign of your power board dying slowly..
    Genius:
  • 3,587 Answers
Well...to an extent..this is most likely a power supply issue internally. There are three major components that fail.
capacitors
xformers
solution...pirate a known good board from one that has a bad tube..
Posted on Mar 19, 2008
Why does a monitoring keep going off?
you forgot to say, screen dark? and power light off.
does the OSD work? Push button that pops up the OSD screen for bightness, does that work>
\can be one of 4 things. 100 % dead.
try it on another PC>
bad power cord
bad video cable.
bad LCD
bad PC, bad Video card in PC or some game using an illegal video card mode.
try another PC and see if the LCD works there.
easy huh?
Sep 30, 2013 | NEC MultiSync 1550V 15" LCD Monitor
No picture. flashing green light. I can see a flahing, faded image at times.
this sounds like the lcd inverter inside the monitor is going bad. You can take it in to a repair shop and see if they can fix it but with the labor and parts it might be cheaper to go out and buy a new monitor for cheap especially since black friday is coming up you should be able to get a great deal on one. And it will have a warranty.
Best of luck..
Nov 18, 2010 | NEC MultiSync 1550V 15" LCD Monitor
No picture and ligh just plinks
kathleen2002, If no picture, then do flashlight test! Six words and no punctuation will not garner much help on fixya here darlin. Tell us more. We need to know how old the unit is and or number of hours use. Did unit work perfectly the day before? Does this monitor get power from a "black lay on floor brick" or does it power up direct from wall outlet? When it worked last, did it have a bright, crisp image displayed on the LCD panel? If you are not a technician familiar with LC display technology you will NOT be able to repair it. As a consumer/user, your options are very limited. 1. NEC warranty if covered. 2. Cash+old monitor swapout with NEC for a refurbished 1550V w/new CCFT/inverter/SMPS. 3. Local Technician to refurbish your unit with new cold-cathode-fluorescent-tubes+Inverter supply repair if required and test unit's switch-mode-power-supply. 4. OR just trade up to a new and younger model. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Sep 25, 2009 | NEC MultiSync LCD1550V 15" LCD Monitor
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Monitor does not wake up.
Check the inverter and backlight bulbs.
Mar 27, 2009 | NEC MultiSync LCD1550VM 15" LCD Monitor
NEC MultiSync LCD1770NX 17" LCD Desktop Monitor
components starting to fail. unrepairable. buy a new one
Oct 21, 2017 | NEC MultiSync LCD1770NX (Black) (Black,...
Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Open Questions:
Computers & Internet Logo
401 people viewed this question
Alun Cox
David Payne
David Payne
