Question about Panasonic Lumix DMC-FZ7 Digital Camera
Remove lens cap
I have a DMC -FZ7 camera and keep getting a remove lens cap error. I really love this cameara and want to get it working again, can you help!?
Did you find a way to fix this problem? i am dealing with the same issue.
Posted on Mar 20, 2008
  • 4 Answers
There are a number of posts about this problem on similar models. I dropped my FZ8 and first followed the advice of some of trying to push the lens or move it back and forth to try to get it working.
In my case, that didn't work, so I followed the instructables instructions and took it apart. The comments there are also very helpful, so pay attention to those.
So try to work the lens back into place, but don't push too hard or you might break the plastic cogs inside. I used pretty much force and didn't damage them, but it could happen.
In my case, even after taking the camera apart, it was pretty hard to get the lens unjammed, but I did get it working again. If you do take it apart, be careful and take your time.
Different solutions work because the actual problem can be a bit different--the cogs that move the lens might be damaged or misaligned, or the pins on the lens itself might be off-track or damaged.
Posted on Jun 26, 2008
  • 51 Answers
Http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
Posted on Mar 26, 2008
Getting lens cap on message push button nothing happens
lens cap means a cap in your camera lens, you have to remove it manually with your hand and not just a push buttons.
May 10, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Remove Lens Cap
We had the same problem with our FZ8. My wife had dropped it and it must've knocked the lens barrel sensor out of whack. I searched google and found a suggestion saying this message occurs when the lens barrel is out of alignment. (http://www.fixya.com/support/t186189-some_reason_camera_keeps_comming_up)
With the lens barrel out, I gently pushed the barrel up, down, left, right and put a little pressure in. Somehow, the barrel worked itself into the right position! The camera works perfectly know. Its worth a shot to save $$$. Be gentle!!
Dec 26, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
For some reason my camera keeps comming up with a "REMOVE LENS CAP AND PRESS > BUTTON" error but the lens cap isn't on the camera :(
it sounds like the lens barrel is out out alignment. Possible the barrel was stuck while it was extended. There is a sensor on the lens barrel asemmbly that must be in the correct position after the camera is turned off. If this doesn't happen then you will get this message..at least this is what I have experienced in my repairs on this camera
Aug 22, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Lens Cap Error
I just encountered the same problem, February 2009. I read all the replies here, and then tried "wiggling" the lens gently by pressing on one side then another. It moved perhaps half a millimeter as I kind of wobbled it back and forth a few times. That did the trick, it's fine now.
I had a problem a few months ago with the zoom not going beyond 2X, and then shutting down requiring a re-powerup. I found that by truly "zooming" quickly from start I could run right by the 2X point and could actually sense a little "tug" as it passed the prior shutdown point. Now that problem never comes up again. That gave me a hint then that there is probably some small imperfection (I envision a miniscule grain of sand) moving about in the lens mechanism, and that it causes zoom problems under different circumstances. Now it's working perfectly, and as this camera has been truly great for years now I'm going to keep fiddling with the lens movement if it should go out again.
Although I must admit I'm also tempted to look at the DMC-FZ28 that is recently out - that's an incredible range! After getting so much mileage out of the original, it may be time to lay out the next $300 bucks. But now that the great original is functional again, I'll hold off - maybe for Z38!!!
Lee, California
Jun 01, 2006 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
149 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
