Question about Sharp AR-407 Copier
Copy to 11x17
I'm trying to copy 11x17 - only scans 81/2x11 size unless I use bypass tray - tried to adjust settings in key operator for size setting for extra and selected extra for both trays but still only copies 1/2 the page. How do I adjust the settings for the trays to match the paper size - message says to check paper size indicator for tray, thought that's what size setting was. Could someone provide some insight on this?
  • 18Margi Mar 20, 2008
    Thanks, I found the settings on the back of the tray. Machine is an AR-287.
  • 81 Answers
Check your settings on tray one. make sure the you set it to 11x17 by the way what is the model of your machine? don't set the machine to auto detect paper.
Posted on Mar 19, 2008
Bypass tray has correct paper size but gives error message to add correct paper size. Won't print
Once you have the message, try removing the paper from the bypass tray, then introducing it again. Alternatively, leave the tray empty then send the data, when it asks for paper, introduce your 11 x 7, and it should work.
Mar 19, 2014 | Konica Minolta Di3510 Copier
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
Paper size
check default setting with bypass try
usually it is letter size change into the a4
Apr 21, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do you load standard sized envelopes into a Sharp MX-2300 copier?
Use the Bypass tray to load it. But first try the paper tray and try to load it there and see if the paper tabs have a size adjustment for envelopes. If not try the by pass
Apr 10, 2010 | Sharp MX-2300N Color Copier
Can I print onto 5-1/2 x 14" paper
minumum size for the bypass is 3.5x5.5 and max is 11x17
minimum, for the paper trays is 5.75x8.25 and the max is11.5x16.5
so it should run 5.5x14 in the bypass tray
1 load the paper in the bypass tray
2 in the basics screen touch paper
3 select the button for the bypass tray
4 touch change setting
5 select custom size and program the size
Nov 17, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Paper Error
The paper lift housing is cracked. The clicking noise is made by the lift gears skipping teeth.
It needs to be serviced...in the mean time, you might try feeding 11 x 17 paper through the manual feeder (bypass tray). Or if you need many 11 x 17 copies, it is possible to set another paper drawer to 11 x 17 size...just set the plastic tag in the front of cassette to LD so the machine knows what size of paper to expect (if tag is set incorrectly, machine will jam EVERY TIME)
Jun 10, 2009 | Toshiba E-STUDIO 450 Copier
Cannot change paper size in drawers
Few things check, first if the paper trays have manual adjustable levers that tell the printer what type of paper is in the tray. The other option is to go to your printer menu from your operating system and check paper assginment on settings.
May 15, 2009 | Lexmark W840 Printer
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
Cannot reduce size from 11x17 to letter
The NP6551 is an analogue copier, using only mirrors and lenses. It has no way of rotating the image. If you want to reduce a 11x17 to a 8.5x11 both peices of paper need to be fed in the same direction, ie short edge first. Change one of your trays to LTR-R ('R' for Reduction) or feed the LTR paper in thru the bypass in the long direction. If you use te bypass you must specify the paper size as LTR-R, you cannot use FREE.
Jul 26, 2008 | Canon NP 6551 Black and White Copier
Sharp AR-407 Copier Logo
166 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
