Question about Sewing Machines
Threading Diagram Pfaff 774 Hobbylock
How do I thread this Sewing machine?
  • Anonymous Mar 20, 2008
    i dont know how to thread my machine
  • kandice best Mar 20, 2008
    i dont know how to thread my sewing machine and i dont have an instruction manual
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: http://www.pfaff.com/mediafiles/threading_guide/index_en.html . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Hi :) Just got a Hobbylock 788 and need to thread
Here is the trick: If you look at your thread spools, left to right, thread machine beginning with thread from spool 3, then 4, then 1, then 2.
Thread 4 is tricky. You must line up the purple line on the big wheel on the right end in order to do this. Thread the machine according to the diagram on the inside, then, making sure you lined up the purple line, push the lever at the bottom of the machine (below threading guides) to the left while holding on to the thread end. This will push the thread up and along the horizontal arm you just threaded.
Mar 21, 2010 | PfaFF Sewing Machines
Threading
Mary - I sympathise with you regarding the "vague manual directions". I have a Pfaff 4862 and if I hadn't found the video, I would never have managed to get it working. There are animated videos at the Pfaff website, just not sure if they would still have them up for the older models - but worth a try, surely.
Feb 02, 2010 | PfaFF Sewing Machines
Threading hobbylock 786 20 year old model
I have a manual. Will copy and send. Give me your address and off it goes.
Dec 10, 2008 | PfaFF Quilt & Craft Pro 7530
Hobbylock 774
If the needle bar is no longer available, the current needle bar can be repaired by cutting new threads in it and changing the screw. Not simple but not rocket science either.Most mechanics can do this.
sewman7
Aug 08, 2008 | PfaFF Creative 7570
Needle keeps falling out of my overlocker hobbylock 774 by pfaff
The threads inside the screw hole are probably stripped. If so you will need to have them rethreaded and a different screw used or have the needle bar changed.For this you should see a technician.
sewman7
Jul 18, 2008 | PfaFF Creative 7570
Sewing Machines Logo
742 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
