Question about JVC FS-D88 Shelf System
This JVC FS-D88 Turn On and Turns Off On Itself
  • Jose Preze Apr 12, 2010
    I Have 2 Unit That are the Same and I Have Change The Belt's On Both Unit For Tape Deck and Now Power Come On for a Few Mins That it Will Cut Off By Itself
    President:
  • 4,070 Answers
Hi! please check the plug of the unit if its perfect tight to the power source. The plug or power source may be a little loose thats why its turning on and off by itself. Hope this helps and have a good one!
Posted on Apr 12, 2010
SOURCE:
My JVC FS 5000 cd player won't turn
check out the power supply all the way upto the switch on button ...
Jan 25, 2015 | JVC FS-5000 CD Shelf System
Ok, If the plug and power source are fine then i believe that the cause of self shut off is the board capacitor. If there are blown or faulty capacitors this are usually the result. Please have a good look at the capacitors.
Apr 12, 2010 | Audio Players & Recorders
Where can I find a subwoofer replacement.....for the JVC FS 8000 or FS 2000?
Contact JVC directly. They will refer you to their parts rep for your area. If the parts are available, you may find the parts to be rather expensive in relation to buying a new one.
Jerry G.
Aug 06, 2009 | JVC FS-8000 Shelf System
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Error code "protect" comes on the scree when turned on
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to reset and dessipate or drain the charged current .
Hope it may help you;
Regards;
VOTIT
Jan 08, 2009 | JVC FS-G5 CD Shelf System
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
CD player shuts itself off as soon as you turn it on
I had the same problem. The F1001 fuse was blown, it is a 1.6 amp, 125 volt fuse, GMA type.
Dec 09, 2007 | JVC FS-S57 CD Shelf System
Cd player opens when turned on and will not function
JVC recommends leaving the unit unplugged for 30 minutes to reseet the system - I'm trying that now, and will keep you posted!
Dec 07, 2006 | JVC FS-G5 CD Shelf System
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
